Am I screwed?
Old Jul 9, 2010 | 05:07 PM
Dube's Avatar
Am I screwed?
Okay I read a bunch of threads on this. So today I picked up my sister we went around town, I did hit a empty garbage bag and something in the road metallic of some sort, just the tire part hit it though. So I was on the highway going about 60 in 5th gear. I hear a extreme rattling noise, sounds like the muffler of some sort or trunk. I got out to see if anything was loose like the trunk or something, trunk wasn't loose. Checked if the tails were loose because I just installed those today, nope those were good too. Okay so now what could be the problem? Is the exhaust suddenly loose? My problem is relavant to these threads. If anyone could chime in with a solution to this it would be amazing. I want to know if I have to shell out 2g's to fix it or if its an easy solution. I have yet to try to turn the cable to 180 degrees. Im not educated enough to do so.'
https://www.evolutionm.net/forums/ev...gear-only.html
https://www.evolutionm.net/forums/ev...t-video-2.html
Old Jul 9, 2010 | 05:29 PM
intuition_d's Avatar
Maybe your muffler is rattling against something, have you checked under your car?
Old Jul 9, 2010 | 05:43 PM
Dube's Avatar
Don't have a lift, i'll have to do that I guess...
But it doesn't make sense it only rattles at 55+
Old Jul 9, 2010 | 05:48 PM
hypnotiq9000's Avatar
on decel or all the time?
Old Jul 9, 2010 | 05:52 PM
AznEvoIX's Avatar
Sounds like one of my old problems.
Since its over 55+ means its probably something caught on by the wind at those speeds.
Check your fender linings where the wheels are to make sure they are rubbing on the tire.
If you see your fender lining loose and kind of shiny from rubbing...... thats your problem.
Old Jul 9, 2010 | 06:14 PM
Yeah, agreed.
I think in that case, its probably not something serious (good thing!)
Old Jul 10, 2010 | 05:46 AM
Dube's Avatar
The decel noise I have in 4th. But I can deal with that, this 55+ noise is unbearable. I need to get it fixed ASAP. I'll check the fender lines and tires.
Old Jul 10, 2010 | 06:29 AM
Draven83's Avatar
The one linkbis for a 10 so i doubt thats the same problem. Didnt u just put a new exhaust on? If so it might be thst having some clearance issues with one of ur braces underneth.
Old Jul 10, 2010 | 06:40 AM
cartuner08's Avatar
I don't think Dube has bought a new exhaust yet, at least if he has he hasn't posted about it.
Old Jul 10, 2010 | 07:41 AM
chaotichoax's Avatar
jack the car up and wiggle stuff underneath...it can't be too hard to find
Old Jul 10, 2010 | 09:03 AM
RockmanX's Avatar
agreed you need to jack this car up its underneath something is loose or not bolted down correctly
Old Jul 10, 2010 | 12:52 PM
Dube's Avatar
Weird it went away but it could come back, I think I might have found what the problem could be heres a picture.
Im not sure how it snapped but it did.
Old Jul 10, 2010 | 01:17 PM
shaggy4267's Avatar
From the picture I noticed you don't have an undertray. That probably didn't help matters when you hit something. I would jack it up and give it a look for any other damage. Just my 2 cents.
Old Jul 10, 2010 | 01:34 PM
barneyb's Avatar
Don't crawl under with the car on the jack from the trunk or any other jack. To do this safely, you need jack stands.
Old Jul 11, 2010 | 08:45 AM
Dube's Avatar
Didn't hear it today, doubt anything is loose. I think its what I took a picture of.
