Weird clutch noise when disengaged
Old Jul 19, 2010 | 11:56 AM
jam05pr's Avatar
I have a comp twin disc and have had a weird noise since day one. I have dealt with it but just curious as to what it could be. When the clutch is pressed, there is a weird "grinding" noice and when the clutch is let go it goes away. "Grinding" is really the only word I can think of to describe it. The car shifts and drives fine its just a little annoying. Some have told me its normal for a twin disc but just want to make sure. Thanks
Old Jul 19, 2010 | 12:39 PM
Svendiesel's Avatar
Some twin disks are well known for being noisy/chattery when disengaged at idle, its most likely nothing to worry about. It also may be your throwout bearing, depending on how it sounds.
Since you said the car drives and shifts just fine, I wouldnt worry...however, if you began getting lockout issues while shifting, the clutch likely needs to be adjusted as its dragging on itself and isnt fully disengaging while you shift.
To find out if the clutch is dragging, get the car off the ground on jackstands so the tires can freely spin. Have a friend with you too.
Start the car and put it in first gear, while youre still holding the clutch in, rev it up and start to two step it. Have your friend tell you if your tires begin to spin while youre two-stepping it. If the tires are spinning, this means your clutch is dragging and needs to be adjusted.
Old Jul 19, 2010 | 02:46 PM
italianevo88's Avatar
9.9/10 times an aftermarket clutch will make a vibrating grinding noise but its nothing to sweat
Old Jul 19, 2010 | 03:25 PM
jam05pr's Avatar
thanks guys, i figured it would be normal but just wanted to see what others thought. I'll give that suggestion a try Svendiesel. So far I havent experienced any lockout issues and the shifting is smooth
Old Jul 19, 2010 | 04:10 PM
jam05pr's Avatar
whats funny is that quite a few people have asked me why my car sounds like that. I guess thats why it got me wondering lol.
Old Jul 20, 2010 | 06:06 AM
DarksideZ's Avatar
It's perfectly normal.
Old Jul 20, 2010 | 10:09 AM
Nofear23's Avatar
Mine does kinda the same thing. Kind of like a moaning noise if that makes sense. Pretty annoying.
Old Jul 20, 2010 | 10:31 AM
GTRicky's Avatar
when i had my carbonetics twin clutch, that **** was loud. when in idle, it sounded like my clutch was bad to some people, but it was just a loud clutch. it did sound like a grinding noise, but as soon as someone said it was clutch clatter or something, i felt better about it.
until i destroyed my clutch about 10kmiles later. now i have an exedy twin HD. No clatter from that one. I love that clutch.
in short, if people ask you if your car is broke, they don't know **** about performance cars and havent been around twin clutch cars.
ct9a gsr
Apr 6, 2019 11:00 AM
shane_evo7
Jun 11, 2017 01:26 PM
Royal Evo
Mar 14, 2016 03:51 PM
romogst
Aug 22, 2013 06:57 AM
love2burn420
14
Jun 9, 2005 08:02 AM
