Making Big Power in 2 Days!
Old Jul 20, 2010 | 07:37 PM
leonevox's Avatar
+1, fp black making 425 are disappointment
Old Jul 20, 2010 | 07:38 PM
metalsaber's Avatar
Not necessarily. Depends on the mods/tune/boost levels.
Old Jul 20, 2010 | 08:07 PM
white_evo27's Avatar
i made 423whp @23lbs on 93... easily could have hit 475-500 @ 29-30lbs... need to change my FMIC and LICP before doing so...
OP, you should make 425 with no problem
Old Jul 21, 2010 | 01:44 AM
EvolutinIX's Avatar
I think you will get it no problem, good luck and let us know the results!
Old Jul 21, 2010 | 04:25 AM
metalsaber's Avatar
On a Mustang Dyno?
Old Jul 21, 2010 | 07:27 AM
manni_t5488's Avatar
stock motor ftw
Old Jul 21, 2010 | 05:36 PM
5LEEPERISAH23I's Avatar
i dont think you will get more than 450whp with stock motor and pump gas. Some car make more than that but not all car are the same bro. Keep ur finger crossed thou
agree thats why i think ill be a 435whp about not going to go crazy
Old Jul 21, 2010 | 05:49 PM
EvoJoeIX's Avatar
you better change to a built block while your at it too...
your not gonna make 475-500 on a mustang dyno and be reliable on a stock block
Old Jul 21, 2010 | 05:59 PM
daishi77's Avatar
well that depends on what dyno too! theres a 15% difference between the dynojet and mustang dyno, mustang being closer to actual whp. I got the same mods basically and making 360whp/356wtq @ 23psi boost in 100 deg weather on the mustang dyno. This is also on crappy 91 cali pump gas to. my mods are unorthadox adj. cam. gears, HKS 272i/e, stock ported/coated mani, rc 1000's, FP black ported/coated and intake pipe, Ti-tek o2 housing, ams uicp/licp, turboxs fmic, tanabe concept g blue TBE. so theres always where you live and what type of gas you have to make those numbers you want and the dyno.
Old Jul 21, 2010 | 07:25 PM
RoMeIX's Avatar
I think you will be able to reach your goal power wise. Good luck man!
Old Jul 21, 2010 | 09:31 PM
uvambo's Avatar
yea think u should hit that no prob, and still be pretty safe all around, good luck man
Old Jul 22, 2010 | 07:23 AM
goodies's Avatar
good luck sounds fun
Old Jul 22, 2010 | 07:29 AM
EvoTsiGuru's Avatar
Is E85 readily available if so make the switch and you will see at least another 65 on top of your pre mature guess cause you can run more boost.
Old Jul 22, 2010 | 08:58 AM
S14Swap240sx's Avatar
so what clutch are you running? also is that turbo internally gated or external? what o2 housing would u be using? sry if i missed it in the original post
nm.. i see twin plate and megan exhaust parts..
damn your all set up
Old Jul 22, 2010 | 02:12 PM
sportsallstar's Avatar
fp red was just put on my car a few weeks ago, i can onyl imagine a black with some meth
