Melted my transfer case.
Old Jul 19, 2010 | 10:18 PM
911_Evo's Avatar
Thumbs down Melted my transfer case.
Ok, I searched, and didn't come up with much. I figured there would be more. My AMS downpipe melted a hole on my transfer case. I can't tell if it's just the bolt, or if there is damage to the TC housing itself.
Anyone else done a bonehead maneuver like this? ( or know of a "friend" that did?) How did you (or your "friend") remedy the situation? Can part of the TC housing be replaced?
I'm pretty pissed at myself right now. -stuie
Old Jul 19, 2010 | 10:29 PM
nelale2's Avatar
wow!!!! pictures would help see the issue
Old Jul 19, 2010 | 10:33 PM
Spoolin4g63's Avatar
how do you figure..? pics would help.
Old Jul 19, 2010 | 10:36 PM
911_Evo's Avatar
I'll whip out the camera in the morning. The DP is touching the TC, and there is fluid leaking from that point. I suppose vibration could have rubbed a hole, instead of melted, but regardless, there is a hole now.
badhabit90's Avatar
how would you MELT a hole in your xfer case??? i really dont think the DP would get hot enough to melt anything of solid metal...pics of said part that was melted??
Old Jul 19, 2010 | 10:38 PM
hamx0r's Avatar
problem rubbed on it causing it to wear away.... you might be using the wrong version DP... your car has ACD?
Old Jul 19, 2010 | 10:41 PM
CJ2X's Avatar
How did this happen?
911_Evo's Avatar
Should have specified, yes I have the 2005 with ACD. The downpipe USED to clear the TC. I have had it on for about 30,000 miles. I don't know what happened.
Old Jul 19, 2010 | 11:11 PM
MuslimEvoFreak's Avatar
I posted it already in my previous thread but you will have to replace the top cover and the gasket because you most likely melted it too. I would take it to a reputable shop and make sure everything is fine on the inside of the unit. If not then it might need to be re-shimmed or send it to Shep. Also, either wrap up your down pipe, get a new one to clear the ACD or use my way...hammer it like crazy.
Old Jul 20, 2010 | 05:39 AM
DarksideZ's Avatar
Did you actually run out of fluid while driving or did you catch it beforehand?
Old Jul 20, 2010 | 07:40 AM
TJSAP00's Avatar
What??? Pictures please!
Old Jul 20, 2010 | 07:47 AM
911_Evo's Avatar
Caught it early, I found a puddle of fluid on my driveway. Pics are coming as soon as I can get out there...
Old Jul 20, 2010 | 07:59 AM
EvosnatcH's Avatar
+1 on the downpipe wrap!!
Old Jul 20, 2010 | 08:11 AM
2003lancerevo8's Avatar
Maybe this is me just because i am to lazy to search this morning, but I have never heard of a downpipe burning through a T-case....
i am really confused on that one.
thanks for the pics
Old Jul 20, 2010 | 08:25 AM
Standing Z's Avatar
There is no way a pipe melted or wore away a hole in a transfer case. This is just a coincidence that the leak is near the exhaust. Take off the downpipe and wipe down the area then look to see where the leak is coming from
