dumb but simple qustion
Old Jul 21, 2010 | 04:16 PM
thepoint4life23's Avatar
sorry for being dumb. but can you weld in a o2 bung for a wideband with the down pipe on the car?
Old Jul 21, 2010 | 04:21 PM
whtrice's Avatar
Veteran: Air Force
Depends on how good the welder. I would personally do it off the car.
Old Jul 21, 2010 | 04:26 PM
i was planning on taking it to buschur if need to
Old Jul 21, 2010 | 04:30 PM
wazzelby's Avatar
You *can, but you want the bung to face downward at least a little so the O2 sensor doesn't collect condensation. Ideally you want the O2 to have more than a 90 degree angle in the pipe.
Old Jul 21, 2010 | 04:32 PM
JEP's Avatar
JEP
I think as long as the bung is near the bottom of the downpipe it should be no problem. But you should have it at a 45 degree angle or so...
Old Jul 21, 2010 | 04:39 PM
SLO-EVO's Avatar
the above are all correct. proper WB02 should be mounted at a 10 o'clock or 2 oclock position. welding the bung on with the exhaust on the car is do-able, just least preferred.
Old Jul 21, 2010 | 05:17 PM
any one have a pic were its should go
Old Jul 21, 2010 | 05:36 PM
CJ2X's Avatar
https://www.evolutionm.net/forums/ev...r-install.html
A few pics on there...
Old Jul 22, 2010 | 06:39 AM
goodies's Avatar
with the downpipe on you are more likely to have small exhaust leaks because its very difficult to get to the top of the bung. it can be done though. if you do it make sure you disconnect to battery just to be safe
Old Jul 22, 2010 | 08:02 AM
so at the end of the down pipe and about the 2 oclock on the pipe
Old Jul 22, 2010 | 10:42 AM
goodies's Avatar
2 or 10
Old Jul 22, 2010 | 02:08 PM
sportsallstar's Avatar
take it off and save the hassle . youll be happy in the end
Old Jul 22, 2010 | 03:58 PM
boostless's Avatar
Originally Posted by goodies
2 or 10
BETWEEN 9 and 3 actually. But im splitting hairs
Old Jul 23, 2010 | 11:38 AM
ratwals's Avatar
Save yourself the future headache of small leaks and take the 5 minutes now to remove the downpipe! That way you can make sure the area around the bung is sealed.
Old Jul 27, 2010 | 11:00 PM
thanks guys
