slipping out of 4th gear.
Old Aug 4, 2010 | 08:00 PM
Charlie-Y's Avatar
Not sure what happen but recently my evo 8 have been slipping out of 4th gear
out of the blue. Not every time but once a day .Shifts into gears smoothly like hot
knife through butter.
I have no mods as far as bushings or short throws ect.
Any ideas where the culprit might be?.
Old Aug 5, 2010 | 02:54 PM
Charlie-Y's Avatar
Help any........one?
Old Aug 5, 2010 | 03:03 PM
brenner's Avatar
spit on it... it'll always go in
Old Aug 5, 2010 | 03:04 PM
grillpt's Avatar
My only experience with a car poping out of gear was with a friends E36 M3. It ended up being his clutch...
Wrong section. Try Evo Engine/Turbo/Drivetrain, or other cars as you drive a wrx.
Old Aug 5, 2010 | 03:20 PM
DarkEvoIX's Avatar
How many miles? Worn bushings, worn cable or bent arm could keep the gear from being fully engaged and let it slip out. Beyond that it would likely be in the trans itself.
Old Aug 5, 2010 | 03:36 PM
Charlie-Y's Avatar
every gear felt notchy when engage except 4th. Every time i accelerate ,I can feel
slight movement of the shifter while driving on 4th gear.
Old Aug 5, 2010 | 03:45 PM
DarkEvoIX's Avatar
I am no expert and you need others to chime in here. My Evo has been mine since new and never abused. The shifter has always been "notchy" which means less than wonderful. Does the shift into fourth feel any different than the others?
The very soft stock motor mounts allow the engine-transmission to dance around.
The shifter will do the same.
Old Aug 5, 2010 | 04:28 PM
Charlie-Y's Avatar
going into 4th gear did not have that locking click .
Oh yeah my car have 65k miles on it.
Old Aug 5, 2010 | 06:37 PM
Charlie-Y's Avatar
This is a demonstration of the shifter play on 4th gear of my evo 8.
3rd gear is vertical from 4th , 3rd is softer than 1,2,5 gears though not as bad
as 4th .
When in drive 4th would slowly slide out to neutral in the process grinding the gear.
Here is the video link.
http://www.youtube.com/watch?v=Cd2fovL7NMU
Old Aug 5, 2010 | 07:16 PM
EVO8STI's Avatar
good luck
Old Aug 5, 2010 | 07:39 PM
turboback1243's Avatar
your car may be broken??
Old Aug 6, 2010 | 05:15 AM
Charlie-Y's Avatar
Any one know how to adjust the shifter linkage cable on a evo?
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
blackout8
Aug 4, 2013 10:55 AM
livnpaintball2
14
Feb 14, 2010 03:43 PM
number 8
Mar 25, 2006 01:22 PM
Go Trees
Jun 23, 2004 09:33 AM
