Upstream 02 No Activity! Help!
Old Aug 10, 2010 | 09:14 AM
XxApollynxX's Avatar
Well before my turbo decided to bite the dust I was throwing codes for a front 02 no activity, low volts, etc. so when I bought a new turbo it came with a 02 sensor so I installed it with that one same thing. I put it on the scanner and it displays 0 volts, I graphed it on the scope just a flat 0 line nothing. Both sensors didn't look damaged, the wires look fine no tears, burns, pulled out wires nothing. I checked both connectors no corrosion, loose pins, nothing but sensors rear 0 volts.
What should I check anything common with this I would have to buy such an expensive sensor again and have it not be truely the problem any advice of what I should look into would be greatly appreciated!
Old Aug 10, 2010 | 10:54 PM
anybody?
Old Aug 17, 2010 | 11:25 PM
Going to bump this again anybody swapped another sensor same thing. Is there any diagrams or testing I can do to the wiring on my car? Multi meter? etc. Is there a common place maybe on the car wiring part that breaks or messes up? Would like to get this figured out!
Old Aug 18, 2010 | 09:51 AM
SeeCoryRun's Avatar
check for resistance in the circuit between the sensor and ecu.
Old Aug 18, 2010 | 09:58 AM
Is there a certain number I should see?
Old Aug 18, 2010 | 12:06 PM
spoolup23's Avatar
Having the same problem mine reads ckt no activity bank 1. Do you have a speed density setup?
Old Aug 18, 2010 | 07:48 PM
UrSlower!'s Avatar
I was wondering the same thing...... I just changed my block for a 2.3L stroker block..... Nothing was wrong with my car, just wanted to upgrade..... And now thats the code I'm getting.......Wonder why?
Old Aug 18, 2010 | 11:48 PM
I still have stock MAF.
Aby@MIL.SPEC
11
Aug 14, 2017 08:39 PM
supak111
Mar 28, 2016 03:27 PM
trinibt65
Aug 31, 2015 12:52 PM
mrm95
Jul 29, 2015 05:06 PM
dtmevox
Cobb AccessPORT
Mar 30, 2015 11:38 AM
