Help: Rear Diff or TCase
Old Sep 1, 2010 | 11:18 PM
sc_s13's Avatar
time to get a shepard t-case. www.sheptrans.com
Old Sep 20, 2010 | 10:23 AM
Darkevolution's Avatar
Noob drivetrain poster here; I have the same noise as the OP and took it into the dealership when I had my 60k service done to get some insight. I mentioned that all the symptoms of a dying T-case (death whine while in 5th gear and above 50mph), but they are telling me the noise is coming from the transmission when they had it on the lift in gear. The previous owner had a evo 8 transmission installed before I bought it so I don't know about the quality of work they did. Also the dealership noted that there were no issues during shifting and all the fluids checked out ok. Any idea if dealership would be wrong?
Old Sep 20, 2010 | 11:28 AM
javicracer's Avatar
i hate when your t-case take a dump.
Old Sep 21, 2010 | 11:05 AM
domyz's Avatar
if you have no death whine in high speed in 4th gear, i don't think that they are wrong
Old Sep 21, 2010 | 01:46 PM
EAVWIDL's Avatar
Definetly t-case for op. Like the other guys have said you can drain the fluids and look for shavings. There is also an inspection cover that can be removed to try and visibly check it out. Although it is very hard to tell anything unless you know what your looking for. I would definetly recommend you give Shep. trans. a call. They have several different packages to choose from. I think they range from several hundred dollar rebuilds to the bullet proof Quaife that they have on sale right now for 1350.00. You can't beat that price for the Quaife with a lifetime warranty. Mine is already headed to Shep as I write this.
Old Sep 21, 2010 | 01:49 PM
EAVWIDL's Avatar
There is a chance that if previous owner installed a used tranny that you may just need to get new sychro's installed. Other than that I'd still consider your t-case as the problem.
Old Sep 21, 2010 | 04:48 PM
Thanks, I think I'll talk to a local transmission shop to see what they think as well. One other thing, I think I have an issue with my front left axle (since my struts checked out fine) as it makes a small clunking noise when turning right. Would this be related to my current transmission issue?
Old Sep 21, 2010 | 06:02 PM
ODUB's Avatar
Originally Posted by domyz
the main problem is that people think that the oil in this TC will last 100kmiles like my granny auto trans who has 150 000kmiles on the cluster and never changed that oil
TC oil should be change at every 2 engine oil changes...
that's a bit excessive. the manual states level checks every 15k with changes every 30k. unless you track the car constantly, that's good enough.
Old Sep 21, 2010 | 10:45 PM
white_evo27's Avatar
between 15k - 20k i change mine
Old Sep 22, 2010 | 05:40 AM
Tuxevo's Avatar
unless you're going 5-6 thousand miles between your oil change intervals that might be a bit of overkill. Not that it a bad thing, better that than the alternative. I would suggest 10k to satisfy any OCD you might have, 15k as a rule. Same with rear diff and tranny.
Old Sep 22, 2010 | 09:08 AM
Locdizzel's Avatar
thanks, that just turned down my OCD, but i still need to change it soon
Old Sep 23, 2010 | 09:24 AM
domyz's Avatar
i know was quite overexaggerating ahahah, i do mine at every 3 oil changes (3500miles X 3 =10500)
Old Sep 23, 2010 | 09:32 AM
EVO8STI's Avatar
every two oil changes?? seems excessive. id say once a year or 15k.
Old Oct 13, 2010 | 12:38 PM
Kasey's Avatar
Im pretty sure OEM recommends every 30k.
Old Oct 13, 2010 | 03:03 PM
xbeckk's Avatar
what is oem about most cars on this site?
15k maximum.
