2-Step Issue
Old Sep 4, 2010 | 01:31 PM
Brsox10288's Avatar
2-Step Issue
I had 2-step put onto my car when I had AMS flash my ecu. I just installed a SS clutch line about 2 weeks ago and now the 2step does not work. I dont understand why this happened. I am doing it correctly like i had always done in the past. Im holding in the clutch at a dead stop with the car in 1st gear... it just goes straight to redline. any ideas?
Old Sep 4, 2010 | 01:33 PM
heel2toe's Avatar
Check your clutch switch. I forget if it is the top or bottom one however one is linked with the two step so if it isnt triggered when the clutch pedal is depressed then the two step will not engage.
Old Sep 4, 2010 | 01:53 PM
Brsox10288's Avatar
Where do i find these switches?
Old Sep 4, 2010 | 07:56 PM
DJAfterShok's Avatar
There should be one under the dash where the clutch pedal is. it should be a pressure realse button.
Old Sep 5, 2010 | 10:00 AM
Brsox10288's Avatar
huh?
Old Sep 5, 2010 | 10:57 AM
OMEGA PHX's Avatar
There should be one under the dash where the clutch pedal is. it should be a pressure release button.
Fixed
Old Sep 6, 2010 | 05:26 AM
Brsox10288's Avatar
Anyone got a picture of this? I thought the one under the dash does not have any effect on the 2step
