Making the evo more fun at the track
Old Sep 17, 2010 | 05:40 PM
hyeteck's Avatar
my suggestions.
- ss brakes lines & motul rbf600 brake fluid
- HIT THE TRACK
- pads
- rotors
- HIT THE TRACK
- swift springs + alignment (-1.9 in the front, -1.5 in the back, 0 toe, max out caster)
- 25mm rear sway bar (progress technology)
- rear trailing arm bushings (energy suspension) + alignment
- HIT THE TRACK
- tires (Hankook Ventus v12) + alignment
- HIT THE TRACK
- tires (Dunlop Star Spec Z1) + alignment
- HIT THE TRACK
- tires (Yokohama AD08) + alignment
- HIT THE TRACK
- RobiSpec KW Suspension
- HIT THE TRACK
- Weight Reduction
- HIT THE TRACK
- Tires (slicks) + alignment
- HIT THE TRACK
in that order.
Old Sep 17, 2010 | 06:25 PM
Pure EvoIX's Avatar
Get race pads (PF01 or DTC 60 or 70), motul 600, ti shims, 2pc rotors, brake ducting, ss brake lines. Aggressive alignment
Then HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
Robispec KW Suspension + alignment
Best Street tires you can get (AD08, Z1*, RE-11...etc)
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
Once those tires die. Get R888 or NT01. More aggressive alignment. Then
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
In that order
10-20s off your lap time from when you first started depending on track. With the same power.
Thunderhill Raceway Park in Willows, CA (3.0 mi)
First track day ever - 294whp. 2:32 lap time
5th track day there- 294whp. 2:09s lap time
Buttonwillow Raceway Park in Buttonwillow, CA
First time there - 294whp. 2:12s lap time
6th time there - 294whp. 2:01s lap time
Moral of story, more track time, more seat time. More fun passing cars with more power and cost 1.5-3 times your car. Even other evos.
Old Sep 18, 2010 | 12:55 PM
stealthyevoviii's Avatar
Originally Posted by hyeteck
my suggestions.
- HIT THE TRACK
- pads
- rotors
- HIT THE TRACK
- HIT THE TRACK
- HIT THE TRACK
- HIT THE TRACK
- HIT THE TRACK
- HIT THE TRACK
- Weight Reduction
- HIT THE TRACK
- HIT THE TRACK
in that order.
Then HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
HIT THE TRACK
In that order
Great advice! Thank you!!
Old Sep 18, 2010 | 03:09 PM
kyoo's Avatar
Of course more seat time is one of the most important things, and definitely suspension if you're on the stock set up.. but i'm willing to bet anyone who's not recommended an upgraded rear diff doesn't have one
