Whats wrong with my evo?? Excessive white smoke
gotcha like what all would you do to it i have cams 750 cc injectos bbk turbo and upper intercooler lower inter cooler megen o2 housing bov and a few more things downpiping
a1311ed4-3675-40a3-889b-5685bdd59eed
1.03.01
1.03.01
Lots of good advice and bad advice in this thread.
Good advice: Get it built to handle more abuse, stop abusing it like that, check PCV valve, check for coolant in oil, check coolant level, check/replace worn rings, check/replace blown turbo etc
Bad advice: get a different head gasket other than OEM (the OEM has been shown to be a VERY reliable headgasket when used with Standard ARP headstuds, it's already multi Layer Steel aka MLS and can handle over 35psi as we proved with Tribals car on the dyno as seen here: https://www.evolutionm.net/forums/ev...t35-build.html ).
Feel free to PM me if you have anymore questions. Understand that these vehicles are not cheap to maintain properly unless you do all your own maintenance and know how to do it properly, when things start going bad they can go very bad very quickly if you aren't careful.
If your car is burning the oil off in short time STOP DRIVING IT. We recently had a customer bring us a car stating that the turbo wouldn't make boost and he wanted us to replace it. In the process of the initial inspection we noticed no oil was touching the dipstick. We decided to drain the oil to put some fresh stuff in and see how much came out. Less than 2 qts came out and this car had been driven a few days before! Once we found this and checked a few more things out. The customer was informed and is now saving for a rebuild on the bottom end. The amount a small copper particles that were found in the oil was seriously disturbing. (Copper is one of the base metals in the type of bearings this individual had.) The turbo had so much shaft play both axial and radial that the thrust washer must have been destroyed and the journal bearings were probably destroyed. Lesson: don't run your car low on oil. If you like that BBK turbo you have on there keep it well lubricated.
Josh
Josh
how is it "bad advice" to recommend getting a aftermarket head gasket, so the stock can hold 35psi with arp studs what if he doesn't have any arp studs? whats the numbers then? he said he is hitting 29 i believe to me that seems like he is at the limit no? what can it hurt to get a head gasket that is proven to go well over 35psi? it cant! therefor not bad advice
Josh
Josh
i think youre right, i have a cosworth before and work great, then i change it to the factory, whenever i blew the stock i might go back to the cosworth, 1.2 mm more my compression.
As stated by a couple of people on here, the stock head gasket is great. If you are taking the head off and putting an aftermarket headgasket on and you are putting stock head bolts back on you are asking for trouble. ARP head studs, the regular ones not the L19's, have been shown for several years to withstand the punishment of high pressure, high powered builds. Yes, there are better aftermarket headgaskets, they are marginally better and cost more than twice the price of the OEM. You are correct in that a little piece of mind can go a long way. But in this case I don't feel it is justified.
Josh
Josh
and let me guess its a 2003 evo too. ha! those youngsters love those cheap evos....just wait til they see how much it costs to repair major things from driving like a tard! priceless when the find out. But hey, live and learn i guess.....
First of all, why are you brake boosting? You don't drive a giant-turbo Supra. If you drive like an idiot, expect idiotic consequences like blown headgaskets.
Check your plugs for discoloration at the tips (if your coolant's green, look for a green tint), drain and check your oil for coolant, and check to see if any sweet smelling water (coolant) is dripping out of your muffler.
OP it's the damn head gasket, although you don't have to see the coolant leaking out the side of the block it's all internal
Im sorry but I am going to have to do it....
LOL
You sound like a real genius, what did you expect would happen? Honestly if you are doing this crap on the roads you deserve it as far as I am concerned.
LOL
