battery terminals
Old Sep 23, 2010 | 12:17 AM
DSMMR21's Avatar
battery terminals
so im not sure if im the only one, but seems to me Mitsu termials arent the best, but would a cracked terminal connected to the battery possibly cause a CEL?
Old Sep 23, 2010 | 12:22 AM
Pal215's Avatar
No, not if its still completing the circuit and not shorting against a ground.
Old Sep 23, 2010 | 12:25 AM
DSMMR21's Avatar
ok thank you, im just trying to narrow down the possibilities of why im throwing a code
Old Sep 23, 2010 | 12:37 AM
TwoFour's Avatar
get a cable, and see what's going on... maybe someone local can help you out
Old Sep 23, 2010 | 07:24 AM
EvilT78supra's Avatar
I've never had a problem with my cables.... Althought it wouldn't hurt to replace that funky junction block with something more sturdy, buy a little extra wire and do I smell a battery relocation coming on?
Old Sep 23, 2010 | 10:55 AM
barneyb's Avatar
I think he means read the code.
Old Sep 23, 2010 | 10:58 AM
rcheung's Avatar
Scan the code and you can find out what that check engine light is all about.
Old Sep 23, 2010 | 11:05 AM
Evoryder's Avatar
Get yourself to autozone
Old Sep 23, 2010 | 11:32 AM
Callahan's Avatar
Any auto parts store should be able to help you with this.
Old Sep 23, 2010 | 12:18 PM
DSMMR21's Avatar
i know what the code is, im just trying to figure out any possiblity of why its there. everything else has been looked over multiple times.
Old Sep 23, 2010 | 12:28 PM
heavens turbo's Avatar
what code? do you have cams?
Old Sep 23, 2010 | 12:38 PM
DSMMR21's Avatar
P0365 yes. kelford 272's ive been posting on here about it searching for an answer
Old Sep 23, 2010 | 03:37 PM
barneyb's Avatar
P0365 is the exhaust cam sensor.
Old Sep 23, 2010 | 09:34 PM
DSMMR21's Avatar
it actually comes up intake camshaft position sensor bank 1 circuit B
Old Sep 24, 2010 | 09:33 AM
barneyb's Avatar
Well, have you had occasion to have the wiring apart that connects to this sensor? If so, I'd suggest pulling the plugs apart again and checking for a bent pin or something. Otherwise, you may need a new sensor.
