Grounding ideas for relocated batteries?
Old Oct 6, 2010 | 08:55 AM
MRmike's Avatar
Whats up EvoM.
I posting to see if anyone has done a DIY grounding kit for relocated batteries. I have my battery relocated to my trunk and would like to have better grounding. Any ideas or pointers to how I would?
Thanks
Mike
Old Oct 6, 2010 | 09:01 AM
GTABurnout's Avatar
I am intrested in this as well....
Old Oct 6, 2010 | 11:54 AM
fwd_josh's Avatar
Reason for better ground? is there something wrong with the way you grounded it originally?
Old Oct 6, 2010 | 12:02 PM
EVO8STI's Avatar
i just relocated my battery today. i ran my ground to the engine bay where it was originally. but i do have issues with the car now. it wants to stall every time i come to a stop.
Old Oct 6, 2010 | 12:09 PM
S0rc3r3r's Avatar
if you keep the ground wire as short as possible to a very good grounding point you should be free of any gremlins. where did you relocate the battery? where did you mount it? if it is in the right rear, use the threaded bolts in either the brace mounts or the fluid reservoir mounts; be sure to scrape away all paint, if you mounted it behind the passenger front seat, use the seat bracket bolt location or center console threaded holes near by, either of these are great places to ground, be sure to use large gauge and as short of a cable as possible.
Old Oct 6, 2010 | 12:13 PM
MRmike's Avatar
Sorry if I wasn't clear in my post. What I mean is that you can purchase aftermarket or oem grounding kits, but since my battery is in my trunk, I cant exactly use the same grounding points for those kits. I'm looking for pointers for grounding spots and how to.
Old Oct 6, 2010 | 05:01 PM
fwd_josh's Avatar
"ground is ground, the world round" if you use a multimeter and ohm out your grounds and they all read >1 ohm, you should be fine. those grounding kits don't do much of anything, if your factory grounds are in good condition.
Old Oct 12, 2010 | 08:47 AM
asrdave's Avatar
shortest ground possible is what you want if you battery is in the trunk then ground it somewhere like the strut mount
Old Oct 12, 2010 | 08:55 AM
EvolutionVIIIrs's Avatar
i moved my battery to the trunk with the relocation kit. I removed the stock spare tire and mounted the box there. The screw that holds the spare tire down was a perfect ground. Just wire-wheel the paint away. You really dont want to go over a 36" piece of ground wire. Take the stock ground up front and find a clean spot on the frame to ground that too. Being the stock spare bolt mount is attached itll all work out perfectly. I can add some pictures of my setup later if youd like..
Old Oct 12, 2010 | 09:01 AM
four-loco's Avatar
i was just thinking about this yesterday! glad i came across this...as i was planning on ground at original location. i will now ground in trunk!
Old Oct 12, 2010 | 09:51 AM
EGHBauce's Avatar
I grounded it onto my coilover/strut bar nut.
No problems at all
Old Oct 12, 2010 | 09:53 AM
_mcjonnyp's Avatar
i have mine grounded to the chassis right underneath the windshield washer pump.. ran relocated battery for almost 3 years now zero problems
Old Oct 13, 2010 | 06:38 AM
Jrah2987's Avatar
Veteran: Air Force
Have you seen these:
https://www.evolutionm.net/forums/ev...-kit-evo8.html
https://www.evolutionm.net/forums/ev...-net-pics.html
Good luck.
Old Oct 13, 2010 | 01:48 PM
prchico19's Avatar
I would run it to the strut mount or somewhere similar. Keep it short and shouldn't have any issues.
Old Oct 13, 2010 | 02:35 PM
MRmike's Avatar
Thanks for the reply guys but what im looking for is ground points that would work with a relocated just like if you were to purchase a aftermarket grounding kit.
