ACD & anti lock
Old Oct 14, 2010 | 07:53 PM
BoostIt's Avatar
ACD & anti lock
So minor issue I wanted to get fixed. ACD lights are all one and my anti lock light is on. My local guy plugged in and couldn't clear the code to get ride of that so he thinks a wheel sensor is bad we just don't know which one.
Only thing I could think is that when I replace the wheel hub and axle on the driver side front, I removed sensor so could it be that one? Any ideas? this is bugging me and want my dash to look normal again.
Old Oct 14, 2010 | 09:06 PM
BoostIt's Avatar
Bueller? Bueller? Bueller?
Old Oct 15, 2010 | 06:52 AM
black95tt's Avatar
I would almost bet it's the abs sensor you messed with. They are very fragile and break easily. One question, why did you have to remove the sensor? You shouldn't have to do that unless you are changing the knuckle.
Just to double check jump pin 4 to ground on the OBDII port and count the flashes on the ACD display. The manual references which numbers mean what.
Old Oct 15, 2010 | 07:03 AM
Dallas J's Avatar
Veteran: Army
The sensors crack internally very easily and its very common for them to break without any external evidence. Measure the resistance across the two pins on the connector. IIRC, It should be about 4 ohms. If its an open circuit then you have your culprit.
Old Oct 18, 2010 | 02:41 PM
BoostIt's Avatar
Help is much appreciated. You're right you shouldn't have to take it off however my axle was seized inside the hub so I had to take it off to try to remove it and wound up having to replace axle and wheel hub. I'll look to replace that sensor. I can't see the other ones being bad bc I never touched them. Thanks.
