ETS intercooler fitment questions
Old Oct 16, 2010 | 01:18 PM
fareastkorean's Avatar
Hello all,
I'm having issues putting my bumper back into place as the ets intercooler (3.5 inch core) I bought for my evo 8 as it is not fitting properly. I already cut the little mesh part on the front bumper and the metal piece that holds the bolt to where the crash beam is inserted into. For some reason, it is still rubbing.. I did not that I had to modify the evo 8 front bumper this much to fit the standard evo 8 tank on. Did everybody else with the ets intercooler have to modify their front evo 8 bumper? If so could you give me some advice and how to make my install easier please?
Old Oct 16, 2010 | 07:43 PM
rdt1's Avatar
Contact ETS they have great customer service
Old Oct 16, 2010 | 09:59 PM
DawnoffateX's Avatar
Mine was pretty much as much of a nightmare as something that only requires 3 bolts could ever be. Evo 9.
Old Oct 16, 2010 | 11:00 PM
djikonatx's Avatar
I know just what you mean....i had too kinda bend the side mounts on mine at the ends.then just to have a little more clearance i put a couple if washers on the crashbeam as spacers to have more space for the ic.
Old Oct 17, 2010 | 08:07 AM
evo8426's Avatar
mine was a very simple install, only problem i had was getting the couplers onto the endtanks along with the ic pipes. this was on an evo 9
Old Oct 17, 2010 | 09:02 AM
Andrewkbmx's Avatar
ive heard 3.7 is the max with the stock crash bar so your probably just having a hard time.
Old Oct 17, 2010 | 09:56 AM
xbeckk's Avatar
I have the 4 inch, had to cut the crash beam a little. I also trimmed the spacers that came with the kit to make the i/c sit back, probably trimmed them half way.
And like you say, the bumber cover is a bit of a pain, I had to cut some plastic from the bumper and install the pipes before putting the cover back on. Ended up looking really good though.
Old Oct 17, 2010 | 03:49 PM
Thanks for all the feedback everybody I think I know what I have to do now. I thought I was maybe installing the intercooler wrong but I guess a lot of people had to modify their bumper in someway. I am going to grind some of the crash beam off where its rubbing against the bumper and trim the bumper this weekend.
Old Oct 18, 2010 | 07:27 AM
l@ndry's Avatar
you can remove the crash beam and sell it to me..I need one. LOL
Old Oct 18, 2010 | 07:30 AM
jasserv's Avatar
On my VIII I had to shave down the metal bracket that holds the mesh and has the hole where the bumper bolts back on... After this no issues.
Old Oct 18, 2010 | 08:44 AM
ETS Michael's Avatar
This is correct.
Thanks,
Michael
Originally Posted by fareastkorean
Hello all,
Give me a call at 360-263-3748 and I will take care of you.
Thanks,
Michael
Old Oct 18, 2010 | 09:03 AM
4RETECH's Avatar
Also check your couplers. Place the bumper on before you tighten them so they are not hitting the lower section of the bumper.
Old Oct 18, 2010 | 12:09 PM
GrnEVO's Avatar
Look at that ETS just jumps right in here to help out. That's why they're getting my business lol
Old Oct 20, 2010 | 10:55 PM
Solley's Avatar
Agreed! they really seem to be interested in the customer which is great! i just got a 4" IC and i haven't installed it yet, hope it isn't too hard
