Evo IX oem question
Old Oct 17, 2010 | 04:05 PM
Evilution23's Avatar
Evo IX oem question
Just bought an Evo IX front bumper basically BNIB from someone. it came with the push pins for the top but also came with 16 pins. what are these pins for? (the bumper did not come with the mesh grills)
Old Oct 17, 2010 | 06:11 PM
S0rc3r3r's Avatar
photo of the pins?
Old Oct 17, 2010 | 10:19 PM
josel_atr's Avatar
prolly pins for the undertray?
Old Oct 18, 2010 | 05:42 AM
Lumpskie's Avatar
Not sure about the front bumper, but the rear bumper mounting hardware uses pop rivets
Old Oct 18, 2010 | 07:13 AM
mobilman's Avatar
under tray, under hood, wheel wells, ...extra ones?
Old Oct 18, 2010 | 07:22 AM
l@ndry's Avatar
some are deft for the fenderwells
Old Oct 18, 2010 | 02:21 PM
these are the pins
Old Oct 18, 2010 | 02:26 PM
newimportowner's Avatar
Those look like rivets,
Old Oct 18, 2010 | 02:39 PM
Ryan.Kauz's Avatar
Those are for stabbing yourself in the eye after giving up on the plastic screw clips for the undertray.
try using these instead:
https://www.evolutionm.net/forums/ev...ion-clips.html
^The above is true, however to answer specifically what those pins are, they are the rivets used for mounting the black metal support brackets to the bumper (directly under where the headlights are and above the crash beam)
Old Oct 18, 2010 | 02:48 PM
they are sharp enough to stab an eye out . the black clips i exactly knew where they went but now i see what those clips are for. thanks for the helf
Old Oct 18, 2010 | 02:50 PM
SLO-EVO's Avatar
those are rivots. Generally to get the bumper mounts / hardware on (metal brackets).
Old Oct 18, 2010 | 03:13 PM
l@ndry's Avatar
deft rivets my friend
Old Oct 18, 2010 | 06:10 PM
four-loco's Avatar
are the metal support brackets needed 100%? will the bumper hold up ok without them?
Old Oct 18, 2010 | 07:46 PM
Jerm__'s Avatar
yup, those are pop rivets.
Did you try contacting the seller?
Old Oct 18, 2010 | 08:40 PM
four-loco's Avatar
i believe someone actually mentioned in the thread what their for...
