Boosting question
Old Nov 30, 2003 | 05:55 AM
rbm3's Avatar
Boosting question
I'm not exactly what forum I should put this in..but here goes! (Yes, I did search but couldn't find anything close enough to my problem.) I have a 93 Evo and I have a HKS EBC installed, when the car hits 0 boost with the BC on the car jerks a little bit...and then when it gets passed .6 and up to .9 the car starts to jerk again. When I have the BC turned off it still does it but not nearly as much. I looked at the hoses and I can't see any leaks, I replaced old spark plugs with brand new Denso Iridium, new fuel filter...doesn't seem to help any! Any ideas?
Old Nov 30, 2003 | 06:31 AM
nastea's Avatar
fuel cut
Old Nov 30, 2003 | 06:43 AM
rbm3's Avatar
How would I stop the fuel cut?
Old Nov 30, 2003 | 06:47 AM
nastea's Avatar
well i think your readings might be wrong, i'm not an evo expert, but it sound like a fuel cut, which is initiated by an "overboost" or too much boost......
Old Nov 30, 2003 | 06:51 AM
rbm3's Avatar
I just looked at how the previous owner of the car has the vacuum lines setup...I don't think they are right. He has the little air filter almost halfway to the engine when they arent supposed to be more than 3.9 in from the EVC box..and that same line has no vacuum at all (it connects to the wastegate - is that normal?)
ds18's Avatar
Fuel cut?? At 0 - .9 boost? How's that possible?
Old Nov 30, 2003 | 06:53 AM
nastea's Avatar
does the line to the waste gate get any pressue, i mean can you test it for positive pressure also?
Old Nov 30, 2003 | 06:55 AM
rbm3's Avatar
I don't have a tester but I put my finger on the hose coming from the wastegate and didn't feel anything
Old Nov 30, 2003 | 07:01 AM
nastea's Avatar
well pressure should be sent to the wastegate from the controller. hence the name wastegate.
Old Nov 30, 2003 | 07:04 AM
rbm3's Avatar
So there wouldn't be pressure until after the turbine was spooled?
Old Nov 30, 2003 | 07:06 AM
nastea's Avatar
shouldn't be, on mine, the vac line that goes to the wastegate, comes off the closed side of my MBC, so until that ball pushes up and opens that side, i wouldn't see any pressure on the line....
Old Nov 30, 2003 | 07:10 AM
rbm3's Avatar
Would those hoses being messed up in anyway (including those air filters) cause the problems I described?
Old Nov 30, 2003 | 07:55 AM
nastea's Avatar
yes, if your EVC or boost controller isn't connected right, your probably over boosting
Old Nov 30, 2003 | 08:41 AM
rbm3's Avatar
Sounds like the problem, I know the over boost light turns on as soon as it goes passed 0 :P
Old Nov 30, 2003 | 08:44 AM
nastea's Avatar
hence the temporary loss of power, due to the ECU, i'm assuming since you probably have an evo II, that mitsu incorporated this feature back then
