fp5r cams
Old Oct 26, 2010 | 08:14 AM
EvoJoeIX's Avatar
fp5r cams
Is it possible to use these cams in a stock head? I know you need springs/retainers for them. But other then that can you just drop them in?
Old Oct 26, 2010 | 08:26 AM
05blue8's Avatar
Yes but keep in mind they are designed for bigger turbos which require higher revs to get into the efficiency range which require motor modifications to get to produce the power
Old Oct 26, 2010 | 08:31 AM
still*boostn's Avatar
+1!, plus your stock head/intake manifold will only flow so much,.. 272's are more then big enough.
Old Oct 27, 2010 | 02:15 AM
EvoJoeIX's Avatar
I don't have a stock intake manifold but head is stock
Old Oct 27, 2010 | 02:19 AM
KX250Fmotoracer's Avatar
what turbo are you running and what are your goals, because thats a pretty radical cam!
