Evo IX noise! help Video inside
Old Nov 15, 2010 | 09:43 PM
rongdoer's Avatar
Apparently ix heat shields just drop off the car regularly. I had a grinding sound coming from the rear that would speed up with rpm. Turns out a portion of heat sheild had dropped off and lodged underneath the rear diff.
Old Nov 16, 2010 | 06:27 AM
impact blue's Avatar
It sounds like its coming from the turbo itself. I would take off the valvecover to make sure the timing belt isnt ripped or torn. Then after that I would make sure all my lugnuts are tight. Check for shavings or carving grooves in the turbo then check it for shaft-playa nd metal shavings. Thats about all I can think of hearing noises like that.
Old Nov 16, 2010 | 06:29 AM
stock clutch? could be a throwout bearing on its way out? or perhaps something touching the pressure-plate.
Old Nov 16, 2010 | 06:58 AM
ev_shon's Avatar
I'm sure it is something obvious but thats why its strange that i havent been able to pinpoint anything yet. Its more of a light ticking noise more than a rattle. the evo runs perfectly still and i havent seen where the noise has affected anything. Ive checked for anything that could be loose, and it makes the sound completely out of boost, and after looking at my turbo seems to be okay, also the ticking doesnt increase in speed or volume as the rev increases.
Old Nov 16, 2010 | 08:25 AM
Brsox10288's Avatar
Check your brakes..
Old Nov 17, 2010 | 03:37 AM
Lord Len's Avatar
thanks for the advise everyone it was raining yesterday, so today or tomorrow i will jack up the car and check the brakes heat shields and move on to the turbo
Old Nov 17, 2010 | 03:39 AM
Lord Len's Avatar
the previous seller said everything was stock but at the dealer they showed me there is a red pressure plate in there
evo_pirate
Jan 21, 2016 09:42 AM
Icegod87
Sep 24, 2014 04:48 PM
wangboy925
Evo X How Tos / Installations
Aug 10, 2013 11:10 AM
SRTRaceR04
For Sale - Cars For Sale
Jun 11, 2012 12:02 PM
Chino1
Nov 26, 2010 05:42 AM
