low oil pressure.. help
Old Nov 1, 2010 | 04:57 AM
blueice288's Avatar
Hi,
i have a 2.3l build with a fp red turbo. My build are as the follow
manley forged 100mm crank
manley turbo tuff rods
manley stroker pistons
stock head with SS valves, springs and retainers
balance shaft eliminator kit
AEM EMS
AEM wideband kit
Brad penn 20-50 oil
ACL racing series bearings
clearance plastic gauge tested
motor has 300 miles on it
after breaking in the motor we decide to put in an AEM oil pressure gauge but at start up the motor only reads 35-40psi at cold start. After idling for a min or so i rev it to 3500 rpm and it drops to 30-35 psi then goes up back to about 35-40 psi when its back at idle. I then changed the oil pump to a new one but same problem. Then i added washers to the pressure relief spring but same problem again. I was wondering if anyone has any ideas what can be the problem with it.
Old Nov 1, 2010 | 08:31 AM
scoobync's Avatar
try to use another oil pressure gauge/sending unit, just in case if the reading wrong.
Old Nov 1, 2010 | 10:27 AM
blueice288's Avatar
already tried that with a defi oil pressure kit and same readings
Old Nov 1, 2010 | 10:36 AM
evodood's Avatar
what balance shaft eliminator kit did you use?
Old Nov 1, 2010 | 11:18 AM
240sxzenki's Avatar
possibly the balance shaft eliminator kit caused oil pressure low
Old Nov 1, 2010 | 07:01 PM
blueice288's Avatar
used a buschur balance shaft eliminator kit
Old Nov 1, 2010 | 07:25 PM
TJSAP00's Avatar
Makes me want to put an oil pressure gauge in pronto... Subscribing to see what's causing it..GL
Old Nov 2, 2010 | 10:22 AM
evodood's Avatar
Were the correct bearings installed with buschur's kit? with the balance shafts eliminated the stock bearings need to be removed and the kit bearings need to be installed. since there is no shaft there is no need for the stock bearings with oiling holes to be in there that will cause low oil pressure. that's why the eliminator kits come with new "block off" bearings.
messing up the bs eliminator install is the only thing i can think of unless the entire build is bad
Old Nov 2, 2010 | 10:48 AM
Ev0ikon's Avatar
Did you also replaced the oilpump assy on your rebuild?
What is the piston-to-wall clearance?
Mine is .040" and I get about 75-80 PSI on cold start. Then eventually set down to about 25 warmed idle.
Old Nov 2, 2010 | 02:04 PM
evodood's Avatar
^^^^ his first post says he changed the oil pump and got the same result
Old Nov 2, 2010 | 06:29 PM
blueice288's Avatar
the balanshaft bearings was installed correctly and we know this because we installed it before and i made sure that the hole for both bearings were blocked off. the piston to wall clearance is the same as your .040
Old Nov 2, 2010 | 07:45 PM
YogSaahoth's Avatar
Veteran: Army
what location are u using for ur pressure sender?
Old Nov 2, 2010 | 08:00 PM
420a-t's Avatar
What was your warm idle oil psi at?
Old Nov 2, 2010 | 08:04 PM
YNGEVO's Avatar
my 2.3 build cold start is 85-90psi. I have the AEM digital Oil pressure gauge which makes out at 100. When warm my idle is 40psi and at 4krpm is shld be 98-100+.. Thats how i know i have good oil in car..
Old Nov 2, 2010 | 08:13 PM
nytalonTSi's Avatar
This. Cause if you mounted the sender to the head, that maybe the reason for low reading since it sees oil last. Though it should still read higher then what your getting for pressure.
