High pitch sound in cabin
Old Nov 9, 2010 | 11:42 AM
3vil_3VO's Avatar
I notice at night when I get home from work when im cooling down the car, I hear a high pitch sound inside the cabin. Like its inside my head. But once I turn it off it goes away. Turn the ignition to ON( I dont crank the car on) it comes back. What can it be? I looked around but I couldnt find the source of the sound. My mods are exhaust, hyperground & ignition, AEM analog boost, and digital A/F.
Thanks
Old Nov 9, 2010 | 11:48 AM
Genesis8's Avatar
Probably the fuel pump.
Old Nov 9, 2010 | 11:56 AM
Earthen's Avatar
I will second that, I can hear mine if its quiet out and nothing else is on.
Old Nov 9, 2010 | 12:04 PM
3vil_3VO's Avatar
I only hear it good at night when its quiet.
Old Nov 10, 2010 | 06:22 AM
Jrah2987's Avatar
Veteran: Air Force
Remove your backseats and put your ear close to the fuel tank/pump assembly. If that's where the noise is then it's your fuel pump. Nothing to worry about. In fact, if you get the Walbro 255, it's going to get a little louder.
Just remember Evos are far from luxury (besides the seats), so get use to annoying rattles and noises.
Old Nov 10, 2010 | 07:08 AM
escodotcarter's Avatar
probably walbro whine
Old Nov 10, 2010 | 07:09 AM
Frank120's Avatar
Transercase!!! Lol. Just kidding
Old Nov 10, 2010 | 07:13 AM
SPANKED's Avatar
Your girlfriend in the trunk maybe...
Probably your fuel pump but try to move around the cabin to see if its coming from the back or the front. You could also be getting an electrical whine from your radio... is it the stock radio?
Old Nov 10, 2010 | 07:34 AM
DSM1320Josh's Avatar
Fuel pump!
Old Nov 10, 2010 | 07:49 AM
Ev0ikon's Avatar
Next time wrap your head in aluminum foil and listen if you could hear it.
I'll go with the fuel pump too.
Old Nov 10, 2010 | 10:17 AM
3vil_3VO's Avatar
Don't scare me like that. Just kidding.
Ill check under the backseat for the sound.
