Coilover FAIL!!!
Old Nov 11, 2010 | 03:42 PM
delongedoug's Avatar
Originally Posted by e4on2e5
probably not... im jus glad i didnt break anything on the car itself... then i would def be pissed... gave midas a called gona go tomorrow morning and see how much they quote me...
For the love of god, no!!!!!
It's been said, but PB Blast the hell out of the bolts and let them sit for a while. Then use a big long breaker bar (with a ***** bar if you must, no shame), not ratchets. These bolts are torqued to 123ft/lb and have 139k miles of rust/seizing on there. These are the things that make working on a car a nightmare. The task at hand isn't hard, it's the unforseen obstacles.
Old Nov 11, 2010 | 05:19 PM
warstang27's Avatar
like everyone else said,
PB blast it, torch the crap out of it untill its glowing and then hit it with a breaker bar, that is a guaranty to come off, i have yet to find a bolt that wont come off with those steps, and use real tools theres many that may claim to be 'heavy duty' and ive tried them but i always go back to craftsman and snap on, the rest are worthless
edit: just saw you were going to go to midas, im with delongedoug DONT!
Old Nov 11, 2010 | 05:28 PM
Raptord's Avatar
Sounds like the sort of thing that usually happens to me. I tried taking off my front bumper for 3 hours today and never managed to get the bloody thing off!
I also agree with going to a performance shop rather than more "popular" places. They're used to doing oil changes and brake jobs, not a full-on coilover installation.
Old Nov 11, 2010 | 05:41 PM
e4on2e5's Avatar
lmao... front bumper...?!? lol... i was using craftsman ratchets by the way... i drenched with wd40 and gave it some metal/metal hits at the top to see if it will loosen up the bolt... but nothing...
and yes... i was turning the bolts the right way (or atleast attempting to) lol... after the 3rd ratchet i called it quits... i'll follow the advice and avoid midas... i'll try contacting a actual tuning shop for this job... im just hoping they don't rape my wallet much...
Old Nov 11, 2010 | 05:53 PM
GTijoejoe's Avatar
jeeeeez.... I undid my FR damper @ 19k miles and it was really really on there... sounds like you needed some heat or some impacts.
Usually if I can't undo a bolt from a breaker bar... I know that I am getting close to the limit of breaking the bolt... I than start using a hammer for some impact shock to break it loose... of course soaking it w/ PB blaster and using some heat.... a trick that has worked for me.
Old Nov 11, 2010 | 07:13 PM
one4's Avatar
it will be cheaper to buy an impact than take it to a shop lol... dont go to midas. take it to ttp if you want to take it to a shop.
Old Nov 11, 2010 | 08:56 PM
TommyGunMR's Avatar
If you are in Orlando you can call Pop at All Version 407.228.8282
Old Nov 11, 2010 | 09:06 PM
MyEvo8Urs's Avatar
I pulled my motor trans and tcase with a 150 dollar craftsman set, about 3 ratchet replacements, and a 12" pipe I call the enforcer...
Old Nov 11, 2010 | 10:45 PM
MonsterTurbo6's Avatar
The lower strut bolts on most cars are splined so you need to hold the bolt with a wrench and then take the nut off first then tap the bolt with the splines through the hole... not sure if the evos are like that...but pb blaster and an impact gun are your friend.
Old Nov 11, 2010 | 11:05 PM
localtoys73's Avatar
sent you a pm, ill help you out if you want. or tell you a good place to go
Old Nov 12, 2010 | 06:27 AM
Appauldd's Avatar
If you are planning on wrenching on your own car....do yourself a favor and invest in AIR TOOLS. An impact wrench with a set of impact sockets will make your life much easier. 20+ years of mechanic experience will teach you a lot when it comes to using the correct tool(s) for the job.
With the proper tools you can swap in a set of coil overs in about 45 mins. Most of that time will be taking the wheels off.
As others have stated....letting the bolts soak in BP Blaster for about 10 minutes before you start will make the job easier.
Paul
Old Nov 12, 2010 | 06:32 AM
alphadux_evo's Avatar
some PB blaster can help to loosen those bolts!!!
Old Nov 12, 2010 | 06:37 AM
Turbo01s2k's Avatar
Ive came into contact with an air gun not even being able to break a bolt loose. I now use a large breaker bar(prob 20 inches) and my jack handle on the end, pops loose every time!
Old Nov 12, 2010 | 06:44 AM
e4on2e5's Avatar
thanx for the info guys... ima take another swing at it today after looking around for reliable/powerful tools... i'll also look into the pb blaster since its like what 80% of u on here are recommending
Old Nov 12, 2010 | 07:14 AM
Jerm__'s Avatar
Originally Posted by ErikB
Big *** breaker bar is your friend!
true this! haha
Its really not that hard to install. Use some Liquid Wrench. Spray it around the bolts and nuts and they'll come out a lot easier, it cuts through rust
