Blew something at the track... another stock block done :(
Old Nov 20, 2010 | 12:32 PM
evoforlife's Avatar
Yeah it was pretty aggressive for stock motor especially with the fp red having a tiny exhaust housing, but i have a goal of running 10s on pump with the red and i intend to do so no matter what it takes
Old Nov 20, 2010 | 12:44 PM
Brew City Evo's Avatar
Sucks when this type of thing happens, but at least you have some other fun cars to keep you occupied while you wait to find out what happened. Good luck.
Old Nov 20, 2010 | 03:39 PM
drifthobo's Avatar
I guess one day we'll all go through a rebuild on our motors if we decide to keep them for awhile!
Old Nov 21, 2010 | 08:13 AM
Jerm__'s Avatar
Sucks bro. Hopefully its just the HG that blew!
But ya, your running a lot of boost for the stock block but money doesn't seem to be a problem for you hahah How's the R35 in comparison to your evo?
Old Nov 21, 2010 | 08:26 AM
AdamWest's Avatar
sorry to hear it man, hopefully its the headgasket.. white smoke and coolant sound correct.. but keep us posted, im interested to see what it is
Old Nov 21, 2010 | 09:05 AM
evoforlife's Avatar
I hope its the head gasket too as i dont really want to build 2 motors at once and the gtr is awesome but i have something for the evos that i just love that just have so much differwnt directions to go and i like how they dont have really any electronics.
Old Nov 21, 2010 | 09:44 AM
EVO IXMR's Avatar
Sorry to hear but at level nothing should have went bad unless you had picked up a bad tank of gas or the * was way to high do you remember what it was??The stock frame turbos' are awesome but not on the stock block due to the crazy ramp rates ,fast spool up ,and tq just smacking at low rpms stock rods hate that.The way you described the issue I'm thinking it's just a H.G cause it didn't pull the side rod trick.
Old Nov 21, 2010 | 09:59 AM
evoforlife's Avatar
I only put shell gas in both my evos nothing else and the timing was set so no knock was happening also my tune was done when it was 110 degrees out and the night i went it was 50 drgrees out so im not sure how that would effect anything if anyone could chime in about that
Old Nov 21, 2010 | 10:32 AM
EvoJoeIX's Avatar
Originally Posted by Evolutionn
^ You need to know the engines limits... and never take it near that. Normal boost levels -60whp would've saved this engine, and it probably would have lasted forever.
60whp is a huge difference.... and again WHP doesnt matter. torque kills motors, not horsepower
Old Nov 21, 2010 | 11:31 AM
EVO IXMR's Avatar
I'm with evojoe tq kills the block.
Old Nov 21, 2010 | 11:33 AM
EVO IXMR's Avatar
Well if the temp dropped that much your boost must have spiked over 5 psi so you were 35 psi instead of 30 psi..
Old Nov 21, 2010 | 11:34 AM
evoforlife's Avatar
It didnt i checked it before i ran the car to make sure it was only hitting 30psi
Old Nov 21, 2010 | 11:41 AM
EVO IXMR's Avatar
So it probably did spike that high ..what gear did this problem occur??Were you logging?Also What gear was it hitting 30 psi when the tune as done?
Old Nov 21, 2010 | 12:17 PM
Vibrant's Avatar
There is no way that your car tuned @ 110° saw an ambient temp drop of 60°, and didnt spike. How is your boost regulated? Ecu? Manual? EMS?
Old Nov 21, 2010 | 12:23 PM
evoforlife's Avatar
4th gear problem accured and tuned in 4th gear and no i was not logging just looking at my boost controller to make sure it didnt go past 30 psi
