o2 sensor question
Old Dec 3, 2010 | 11:59 AM
malac0da13's Avatar
o2 sensor question
I have an AEM wideband and an Apexi turbo timer which can display the o2 sensor reading from the ecu. I know this isnt exactly accurate for tuning or anything but when sitting at idle the AEM will read a relatively stable A/F but the turbo timer will fluctuate randomly. Could this mean that one of my o2 sensors is going, does it mean something else, or does it mean nothing at all and I am being paranoid?
Old Dec 3, 2010 | 09:06 PM
adam_79_2005's Avatar
if you have a stock turbo, theres no real reason to run a turbo timer, in my opinion, during wot, generally 11.2-11.8 range is where you'd like to be, idle, 13-15 or higher depending on your set up, the lower the number the richer you are running, higher the number the leaner your running, lean is worst then rich, hopefully this helps some what.
Old Dec 4, 2010 | 08:51 AM
jasons9594's Avatar
x2^^^
the turbo timer only reads the stock o2 wich is a pretty basic reading if i remember right its only a 2volt split so it doesnt help you much(pretty much a narrow band)
Old Dec 4, 2010 | 09:07 AM
barneyb's Avatar
Yeah, the stock sensor is narrow band meaning the voltage drops off sharply on either side. A good sensor should vary all the time. So, your reading is telling you something, it is telling you the sensor is working. If it was bad it would produce a flat reading.
Old Dec 4, 2010 | 09:34 AM
Force 6's Avatar
hmm
Old Dec 4, 2010 | 10:48 AM
born2die88's Avatar
yeah .... 2nd
Old Dec 5, 2010 | 05:53 AM
malac0da13's Avatar
Up until recently it actually followed the wideband fairly closely. Like within a few decimal places. Now when the arm is reading a steady 14 something and a only changing a few decimal places. The turbo timer now fluctuates from 14 something to 20. When an o2 fails doesn't it read full lean?
Brsox10288
Feb 26, 2009 01:31 PM
evilevo22
Oct 3, 2007 02:36 PM
Grimsta
Aug 11, 2007 01:03 AM
Rob W.
Sep 15, 2006 12:42 PM
ak47po
Sep 12, 2006 07:04 PM
