Need HELP
Old Dec 21, 2010 | 06:04 PM
Bigevo's Avatar
Need HELP
Ok i have a coolant leak and i found it. Well its coming from the turbo coolant line i think its the return its the one between the motor and the turbo the hard side to get to and i cant tell if the line is cracked or the banjo fitting is leaking or the crush washer is bad? My question is do i have to remove the turbo to replace the line or the crush washers??????
Old Dec 22, 2010 | 07:15 AM
Bigevo's Avatar
Bump
Old Dec 22, 2010 | 05:40 PM
Bigevo's Avatar
I found the problem the water line to the turbo was cracked because the bolt was never installed to hold the line in place. So whoever tighten down the line put a crack in it. I think it finally just rub a hole in it.
Old Dec 23, 2010 | 02:34 AM
The Storm's Avatar
Ouch that sucks man, I'm glad you found the problem. Nothing worse than not not knowing what the heck is wrong with your car.
Old Dec 23, 2010 | 05:28 PM
Bigevo's Avatar
Yea i just pulled the turbo and manifold off it was a lot easier to do that and plus im getting use of the car working on it that is lol. But since i have the turbo off im getting it ported
