Got a FS635 kit few questions
Old Jan 9, 2011 | 06:45 PM
JDM EVO PANAMA's Avatar
1997 Evo 4 weigh 2800 lbs
Ported and Polished Head
Farra Valve and Springs
GSC S2 274
ETS 4" intercooler
Arias Piston
Manley rods
ACL Bearing
Spec 6 puck clutch
HKS 3" intake
BR FS635 kit PTE 6262
Evo 8 ECU
Sparktech Basic
Do I need to change my maf sensor and why if I do and why if I dont?
Will my stock drivetrain hold up?
Also anything I should add?
Old Jan 9, 2011 | 06:57 PM
Evilawd100's Avatar
your stock maf sensor should be fine. Just depends since im sure the maf sensor on an evo 4 is probably more restricted im sure you can run a different type of system without going standalone that will allow you to run enough air into that big turbo. Seems like your going to be pushing a good amount of power so drivetrain should be fine but after launches and what not it might need to be addressed in the future.
everything looks fine other than i didnt see injectors? will you be running race gas or pump
Old Jan 9, 2011 | 07:00 PM
Ok injectors are PTE 1200
Gas will be panamanian pump gas which is 90 octane plus torco octane booster which should make it around 95 oct and c16 race fuel.
Old Jan 10, 2011 | 07:52 AM
any other suggestions from anyone else
Old Jan 11, 2011 | 10:21 AM
dabeast's Avatar
how much hp are you looking for? if it were me i would add a ported intake manifold and throttle body and maybe a double pumper.
Old Jan 12, 2011 | 11:15 AM
I am hoping to make 500-575 pump and want to get the DW 300 pump or modify my walboro.
650 whp on C16
also found out the turbo is a PTE 6235R
Kidloco51
Jan 9, 2023 09:06 AM
tscompusa
Oct 20, 2015 11:40 AM
vaflyboi757
17
Sep 16, 2014 02:05 PM
jmichetti
May 17, 2014 06:23 AM
tscompusa
Nov 26, 2013 05:01 PM
