whats this sensor for on the back of block?--PICS INSIDE?
Old Jan 19, 2011 | 03:12 PM
Darkn3s's Avatar
Not sure if this is the right section but.....................
well im assembling the motor after 3 months of down time and came across a few things i forgot about or have never seen. so if you guys could help me point out whats what when i post pics thanks.. couldnt really search it since i didnt know what it was called in the first place
1- if someone could tell me what this sensor is for (the one Green arrows are pointing to) and what harness it goes to.. looks as if the terminal broke off that went under the phillips screw at the end of sensor
thanks OIL PRESSURE SENSOR
2- under the intake manifold there this bracket with a sensor on it.. i dont remember if its not used anymore since i did the evap and egr delete.. is it safe to just remove sensor or should i leave plugged up to harness? also has vacuum nipples on it EGR SOLENOID
3- when we were removing the power steering compressor a blue with white stripe wire was ripped from somewhere on the compressor but cant trace where it came from or going into. on pic 1 you can see the little heat shield has a plastic clip on where the wire ran through. heres a couple of pictures
4- what is this? does it go somewhere on trans? looks to be grease inside the hole
Old Jan 19, 2011 | 04:44 PM
kekek's Avatar
1 - oil pressure sensor
3 - (2nd one) breather for the trans. Goes in a hole near there shift arms.
Old Jan 19, 2011 | 04:47 PM
sessanator18's Avatar
2 is your boost solenoid I believe i don't use mine since I have a boost controller
Old Jan 19, 2011 | 04:52 PM
EvoJoeIX's Avatar
that is not the boost solenoid....
shawn360h's Avatar
the blue wire for the power steering pump goes in that black nipple looking thing on the opposite side of the pulley. i dont know what its for but i did the same thing when i did my head gasket.
Old Jan 19, 2011 | 04:53 PM
kekek's Avatar
No. That solenoid is emissions related. The boost control solenoid is near the front left headlight.
Old Jan 19, 2011 | 04:56 PM
I thought near the intake didn't really pay attention to the manifold sorry my b
Old Jan 19, 2011 | 08:15 PM
Darkn3s's Avatar
okay cool do u have pics of the breather?
damn so is the car straight without this connection?.. anyone know about this wire?
ok cool i guess i dont need it
Old Jan 20, 2011 | 05:21 AM
MR Turco's Avatar
#2 is your EGR solenoid.
Old Jan 20, 2011 | 08:32 AM
Darkn3s's Avatar
perfect dont need it
Old Jan 24, 2011 | 04:24 PM
Darkn3s's Avatar
Bump to find answers for #3 and #4
Old Jan 24, 2011 | 10:08 PM
barneyb's Avatar
The wire to the power steering pump tells the ECU when the pump is working hard so the ECU can bump the idle. You probably want that working.
Old Jan 25, 2011 | 08:11 AM
Darkn3s's Avatar
damn anyone how to REattach it? no clue all i see is a black rubber nipple and im sure it went in there but the wire just ripped out and dont know how to fix this
Old Jan 25, 2011 | 08:23 AM
Most Hated's Avatar
green arrow- oil pressure i broke the same clip. havent been able to find the name of the clip or something to compromise let me know if you find anything.
red circle- knock sensor
Old Jan 25, 2011 | 08:42 AM
Bobster22388's Avatar
It may be possible to split the rubber down one side and see if you can reach what's left of the wire inside and solder and heat-shrink it. I don't know how far the wire ripped off in there though, but it's worth a shot at least.
