where do these plugs go
Old Jan 20, 2011 | 06:39 PM
honda-guy's Avatar
purchased my 06 RS with the engine already out off the car. i'm in the process of putting the engine back in the car. i can't figure out where some of these plugs go, i don't even see where there are sensors to plug them in.
EGR is removed and also converted to speed density.
these two plug are on the same harness as the MAP sensor. they are close to the top of the alternator.
the one wire black plug is next to the power steering reservoir. not sure where the yellow plug go also.
this plug is routed next to the thermostat.
Old Jan 20, 2011 | 06:44 PM
Andrewkbmx's Avatar
off the top of my head the yellow is the air bag crashe sensor tie that up somewhere.
Old Jan 20, 2011 | 06:56 PM
4RETECH's Avatar
Top pic. you are missing the vac solenoidthat attaches the end of manifold, and it plugs in there.
Middle, Airbag right front(yellow) sensor. Blue tape is most likely the connector to the AC compressor if you car still has AC.
Old Jan 20, 2011 | 07:00 PM
L888Apex's Avatar
The plug in the first and last pic looks like the throttle position sensor for the throttle body.
Old Jan 20, 2011 | 07:21 PM
honda-guy's Avatar
pic #1 - EVAP is also removed. so i think that's the solenoid that's attached to the end of the manifold, which is where the rectangle plug go. so not sure where the oval plug go in pic #1
pic #2 - ok, i think the yellow plug is for air bag sensor, there's also one on driver side and i do have two sensor for them, don't know where the sensors need to be mounted though. the single wire plug looks like it's for the AC compressor. the AC is removed but i do have the compressor and it has the same plug.
pic #3 - i don't see any sensors in that area where the plug could go in.
Old Jan 22, 2011 | 02:26 PM
smokebomb's Avatar
yellow plug goes to airbag sensors. there should be one on each side of the upper tie bar next to the radiator. i agree with apex, pic 3 looks like tps sensor.
Old Jan 22, 2011 | 03:51 PM
KentStateTsi's Avatar
Veteran: Army
The TPS is a 4 wide connector. 1 is blank. Only thing close that is 3 wide is maybe the speed or reverse sensors on the trans.
Old Jan 22, 2011 | 06:10 PM
honda-guy's Avatar
looks like plug in pic #3 is for the tranny speed sensor.
thanks for all the help so far. i just need to figure where the oval plug in pic #1 go
Old Jan 23, 2011 | 12:15 PM
smokebomb's Avatar
theres a gold bracket with a sensor located on the back of the intake. there is a large vacuum line attached to it. plugs in there. in pic 1 it would be behind the blue tape. there is a grey connecter ( with a "B"marked on it) also plugged in next to it. if its the same as my 06...? oval plug in pic 1...
Old Jan 23, 2011 | 02:37 PM
honda-guy's Avatar
the grey plug with "B" on it is the knock sensor, it's already plugged in. the rectangle plug is for the EVAP solenoid that's attached to the end of the manifold. EVAP and EGR is removed, so i don't need that plug.
still trying to figure what the oval plug is for
Old Jan 23, 2011 | 06:59 PM
4RETECH's Avatar
The connector goes to a vacuum valve behind the connector at "B"
honda-guy
Nov 15, 2017 06:04 PM
honda-guy
Mar 20, 2017 08:17 AM
honda-guy
32
Apr 8, 2016 05:51 AM
honda-guy
Nov 7, 2013 08:49 AM
honda-guy
Mar 7, 2012 09:52 AM
