Evo do-luck poly lips available again!
The new lip does not attatch to the undertray. Most do-luck style ones don't because they sit much lower than stock and are not aligned.
I got a first batch one. Two holes don't line up but whatever. Had to clean out the threads on it too.
BTW: it doesn't come painted guys. What you see is mold release residue. You guys are expecting a great looking aftermarket part for $125?
And to the fitment issue, they have been getting a bad bunch lately. I guess the manufacturer went into high gear without quality control.
Ok finally got around to painting mine and got it on the car.
[IMG]
Uploaded with ImageShack.us[/IMG]
[IMG]
[IMG]
Still needs another coat of clear and some wet sanding.
After some work with the dremel i got it to fit much better too!
[IMG]
Uploaded with ImageShack.us[/IMG][IMG]
Uploaded with ImageShack.us[/IMG]Still needs another coat of clear and some wet sanding.
I installed mine yesterday and it came out pretty good. here are some pics. The only problem I ran into was that I had to use one extended bolt because the one supplied wasnt long enough, and had to dremel the end holes just a bit to get the bolt to line up staight. Other than that pretty simple and straigh forward. I purchased my lip before the crazy prize jump.
