Stock Fuel Rail
Old Jan 22, 2011 | 08:11 AM
evoforstevo's Avatar
Stock Fuel Rail
Hey guys! I'm looking to get my evo 8 running e85 and I was doing research and found that 1050cc injectors are best for my purposes. My question comes with the fuel rail. Can the stock fuel rail handle that big of injectors? Look forward to some replies!!
Steve
Old Jan 22, 2011 | 08:12 AM
fastcolt's Avatar
Yes, should be fine.
Old Jan 22, 2011 | 08:44 AM
06RedRalli's Avatar
Yep will be good enough.
Old Jan 22, 2011 | 12:46 PM
4RETECH's Avatar
Rail is fine, just make sure you have an upgraded fuel pump
Old Jan 23, 2011 | 08:20 AM
thanks guys!!! any recommendation on e85 tune??
Old Jan 23, 2011 | 08:29 AM
fastcolt's Avatar
Yes, tune for e85. LOL sorry couldnt resist.
Every car is different, your going to have to play with the tune. You may be able to grab a base map from a fellow evom'er but your going to have to mess with it to get it 100%.
Old Jan 23, 2011 | 10:11 AM
jdr7919's Avatar
Make sure you have a wideband if you are going to be tuning it your self.
Old Jan 23, 2011 | 10:22 AM
06RedRalli's Avatar
Check the alternative fuel section for all your questions....very good info in there for you.
Old Jan 24, 2011 | 05:20 AM
hardy har har thanks for the help guys!anybody have a guesstimate on HP gains? i just have exhaust and an intake as of now
Old Jan 24, 2011 | 05:42 AM
GreenAWD's Avatar
While on the topic of fuel rails, what is the point where it NEEDS to be upgraded?
Old Jan 25, 2011 | 05:27 AM
and if i get 1200cc injectors with the intention of an evo 9 or fp turbo would i need a second fuel pump? and would a tune keep the a/f ratio in check while i save for the turbo?
Old Jan 25, 2011 | 10:42 AM
06RedRalli's Avatar
When u put the new injectors in you'll have to tune them to get them scaled properly.
Old Jan 25, 2011 | 01:57 PM
Donkeypuncher's Avatar
i would wait and put it all in at once and get one prof tune. Probably good with a Walboro if you go 9 turbo. If you go up to a red on E85, you will need more fuel pump. Im out of fuel right now. I am waiting to try one of the new 340 in tank pumps. If that doesnt work, Il go BR double pumper.
Old Jan 25, 2011 | 01:58 PM
4RETECH's Avatar
NO, I run a single Walbro pump with my 1200cc.
But really, it all depends on your tuner..
You would get a tune now after you instal you current mods and then another tune after the new turbo is installed.
Old Jan 26, 2011 | 09:16 AM
@fastcolt what mods do you have that'll get you 380 on pump? i'm looking to get around 400-425 with e85 since it's easy to access in SD
