What is the benifit of having two map tunes?
Old Feb 5, 2011 | 04:21 PM
Sinister8's Avatar
What is the benefit of having two map tunes?
My question is do I really need a race gas tune and a pump gas tune? Can I just get a tune for race gas and turn down the boost when I use pump gas?
Old Feb 5, 2011 | 04:27 PM
Kracka's Avatar
If you plan on running multiple fuels you really should have a tune for each. With how easy it is to switch between maps there's no reason not to.
Old Feb 5, 2011 | 04:32 PM
Evoryder's Avatar
yes you can. Some people use the second map for a methanol or E85 high boost map which is tuned differently depending on the aggressiveness of the setup. So lowering boost in those cases may not work as well.
Old Feb 5, 2011 | 05:28 PM
williamgasdick's Avatar
Always have different map setups for each driving style.. so easy to just switch
Old Aug 13, 2011 | 06:34 PM
sl8125's Avatar
can you have more then two maps? such as pump gas / ethanol / methanol
Old Aug 13, 2011 | 09:19 PM
evo8426's Avatar
Maybe on a stand alone ecu but you can only do 2 on stock ecu
Old Aug 13, 2011 | 09:46 PM
06RedRalli's Avatar
Yes I'd say it's necessary to have two different tunes...
The race gas timing may be too much for your pump gas to handle...so lowering the boost might not be even safe enough for it...
