Engine compression.
Old Feb 6, 2011 | 02:33 AM
martinPL's Avatar
Engine compression.
Hi,
I was wondering about compression in Evo IX MR engine. How many atmosphere
should healthy engine has??
Thank's
Martin
Old Feb 6, 2011 | 09:25 AM
nismos13sleeper's Avatar
well first question is how many miles does ur motor have, does it have a bunch of timing thrown at it and how much boost is being run through it. depending on those numbers would reflect what the compression test roughly should be. i dont know how much psi they put down stock it mihgt be somewere around 180-200 psi. but mainly u want somewhat level number across all 4 cylinders
something like 162,167,165,160 would be fine/ u dont wanna see like 140,165,162,135 that means u have serious blowby issues/vavle sealing issues also.
Old Feb 6, 2011 | 10:28 AM
YogSaahoth's Avatar
Veteran: Army
According to the service manual:
-Standard value is 163psi or 1128kPa
-Lower limit is 138psi or 951kPa
-No upper limit is given, but like the guy above stated, it depends on car mileage and may be as much as 200psi.
-The key is the difference between all 4 cylinders. No pressure value should deviate from another by more than 14psi or 98kPa.
*Note..compression testing should be done with the vehicle warmed up (coolant temp 80-95*C)
Hope this helps...I trust you can convert psi or kPa to atm
Old Feb 6, 2011 | 11:19 AM
ch1215g's Avatar
SUSPECTED SCAMMER
So 165 165 165 165 is good compression in a sense?
Old Feb 6, 2011 | 11:25 AM
Aaron20's Avatar
I had a Compression Test and a Leak Down Test, my results were Cylinder #1: 175PSI Leakdown 0%, Cylinder #2: 180PSI Leakdown 3%, Cylinder #3: 175PSI Leakdown 0%, Cylinder #4: 180PSI Leakdown 3%. The Leakdown test was a 3 hour test. This was on an Evo 8 motor but the 9 motor should be pretty much the same.
Old Feb 6, 2011 | 11:36 AM
student driver's Avatar
So if I have my engine checked should I ask for a leak down test or do they do it/suppose to, anyway.
Also I thought I heard someone say it would be different pressures "plugs in" and "plugs out"???
Old Feb 6, 2011 | 11:59 AM
Aaron20's Avatar
you cant really do a compression test with the plugs in as the tester goes into the spark plug hole. I would recommend a leak-down test if your going to get a compression test done, but thats my opinion.
Old Feb 6, 2011 | 12:06 PM
YogSaahoth's Avatar
Veteran: Army
Well you have to remove the spark plugs to have access to the combustion chamber. Whoever you heard that from was probably referring to whether or not they left the other 3 plugs in while testing each cylinder. Sure, readings may be different compared to if all 4 are removed during the testing (seems unlikely though). I have always taken all plugs out and tested that way. There is a large range of acceptable compressions, so the value itself isn't as important as the consistency between cylinders. Mitsu manual says remove all plugs and then test each cylinder
Old Feb 6, 2011 | 12:13 PM
Aaron20's Avatar
I agree with this, the compressions might be different but I can't really see why as each cylinder is an individual cylinder and there should be no bleed over. The reason you take out the spark plugs in all cylinders is just in case you have blow by the excess pressure has a place to go and not out an area you dont want like the head gasket...
Old Feb 6, 2011 | 12:52 PM
YogSaahoth's Avatar
Veteran: Army
^Exactly...
Old Feb 6, 2011 | 01:59 PM
Boosted Tuning's Avatar
That is the info for the EVO 8, which is different then the EVO 9.
EVO 9 info:
Standard value: 1,000 kPa (145 psi)
Minimum limit: 637 kPa (92 psi)
Difference Limit: 98 kPa (14 psi)
Old Feb 6, 2011 | 04:35 PM
blaze-619's Avatar
Is it bad if you do a compression test when its cold?
Old Feb 7, 2011 | 12:26 AM
martinPL's Avatar
Ok guys. I have different scale in PL.
Compression for Evo IX should be 9 atmosphere and I have 9 in all cylinders
Evo IX MR with 46 000 miles on it.
Thank's
Old Feb 7, 2011 | 10:01 AM
cant help with that lol dont know enough about different values
Old Feb 7, 2011 | 10:25 AM
xRoguex's Avatar
Thank's
9-10atm's
