not very hot heater
Old Dec 11, 2003 | 10:45 AM
sethevo's Avatar
i just checked the coolant level and it seems to be quite full. i did notice that the intercooler is covered in about 1/2" of ice. would that make it run hotter or cooler? i could see it going both ways
Old Dec 11, 2003 | 11:13 AM
juyanith's Avatar
Hmmm... I can't say that I've been in weather that cold with the evo yet, but I'm suprised that you're getting anything but hot air from the heater. In fact, a couple of months ago when the weather was nice, I almost posted a message similar to this but in the opposite direction -- ie, is the vented air ever cold?
If you ever figure out what's going on, let us know -- it would be nice to have "colder" air when it gets hot again. Maybe there's something in the way the air vents are set up that is altering the mixture of heated and fresh air?
Old Dec 11, 2003 | 12:11 PM
Dale_K's Avatar
Check the coolant level by actually removing the radiator cap (after it has cooled down of course). Sometimes the coolant recovery tanks stop working if the little hoses get loose. Tank remains full but radiator is low. Most modern cars use a better system with a pressurized expansion tank which does not depend on a vacuum to suck the coolant back into the radiator. I don't know why the EVO is sort of outdated. Anyway, if you want to be positive about the coolant you've got to pop the cap.
Old Dec 11, 2003 | 12:33 PM
sethevo's Avatar
ok. i just checked that too. its defenatly full
Old Dec 11, 2003 | 04:37 PM
Dale_K's Avatar
Good. Then there are only 2 other reasons, maybe your coolant is too cool (stat problem, as mentioned by others) or the air damper isn't working (control cable from knob or problem at the damper). Anybody drop something down the defrost vents?
Old Dec 11, 2003 | 09:24 PM
Diesel's Avatar
Originally posted by 992gnt
Haven't driven in 10 degree weather yet, but my heater gets too hot (take off your coat hot) usually and I have to turn it down.
ditto...
Old Dec 12, 2003 | 06:24 AM
Rob W.'s Avatar
Manufacturers use overflow bottles instead of pressurized surge tanks because it's much cheaper.
He didn't say he wasn't getting any hot air. He just said that when it's super cold, the heater can't seem to keep up. I doubt there's any damper or linkage problems. A defective t-stat is possible, but it'd have to be really far out of spec.. probably so far that you'd also see your temp gauge reading way low. (I don't know about anyone else, my mine has never gone above about 1/3 or so, even in summer).
As far as 1/2 inch of ice on the intercooler, I dunno. It seems to me that it'll block the airflow and actually give you a little more coolant heat.
The reason why the vent mode (with a/c off) in the summer doesn't get very cool is because of the hood vent. All that engine heat is also heating the HVAC air inlet (at the base of the windshield). I noticed this quite a bit myself, even at highway speeds. Even if it's only 55F outside, on the expressway I often had to run with the a/c on to keep from getting too hot inside.
Old Dec 12, 2003 | 06:28 AM
nick735's Avatar
Dont complain, i didnt have any heat whatsoever in my old car! The only thing that got me through the bitter new england winters was my heated seats . To me the heater is absolutly fine, but there are people out there that have t find something to complain about.
Old Dec 12, 2003 | 08:52 AM
sethevo's Avatar
i know how you feel my first car (92 ford tempo) didnt have heat for an entire winter....then i got off my *** and replaced the heater core . i wasnt really looking for something to complain about i just wondered if any one else had this problem. my last car (99 eclipse rs) had a great heater i guess maybe i just got used to that. . thanx to everyone who posted. im gonna check the thermostat this weekend. ill keep u all posted.
Old Dec 12, 2003 | 09:03 AM
Sweet bucket22's Avatar
regular lancer heater is not too hot either. Living in Cali it is not usually a problem though
Old Dec 12, 2003 | 10:35 AM
dpardo's Avatar
When I bought my Evo, the heater didn't work at all. I took it to the dealer and they found a loose wire behind the controls. It works very well now.
Old Dec 12, 2003 | 02:06 PM
juyanith's Avatar
Yeah, I attributed it to hot underhood temps, but that's exactly why I find it suprising that sethevo says his heater can't keep up. There's gotta be tons of heat available under the hood (even at 15 degrees F.) Of course the issue is getting that heat transferred into the cabin effectively...
Old Dec 13, 2003 | 08:59 AM
cotmfk's Avatar
Just a couple points:
1.) Before you pull the stat, check your coolant and make sure it's not low!
2.) I had similar problems with my WRX. I've only been down to about 15F so far, so I can't comment on the EVO heater at <10F. But when you are at the limits of the heating capacity, you might try turning DOWN the blower to the second level. As the air passes slower over the heater core, it absorbs more heat, and thus is actually quite a bit hotter. You'll get less volume of air, but if you're sitting in the front seat, that's usually not an issue. On REALLY cold days in my WRX (<5F), if I left it at hi blower, I'd never get warm. But if I tapered it down to 3, then 2, I'd be roasting. It sounds a little odd, but it's true.
I do the same thing, only opposite, in the summer. The A/C in one of my old cars just couldn't keep up at 4, so I would turn it down to 3 then 2, etc.
BrandonIX
15
Jun 12, 2016 08:17 PM
legacydestroyer
Dec 18, 2014 04:08 AM
David Buschur
Feb 3, 2009 04:22 AM
David Buschur
57
Aug 11, 2008 04:55 PM
chriseacrett
Apr 17, 2008 11:21 AM
