How is your APR Splitter holding up?
Old Feb 8, 2011 | 09:51 PM
PKEVO8's Avatar
Just wanted to see how other members have been doing with their apr windsplitters? I usually take mine off in the winter time, but one of the brackets for the hangars stripped off the bumper and I'm missing hardware for it. Anyone know where I can buy replacement parts?
I really like this front lip but I feel like it's useful life is somewhat limited. Has anyone heard of them ripping off before?
Old Feb 8, 2011 | 10:36 PM
evo_xtatic's Avatar
APR on evo X flies off at 120
FWIW, mine ripped off at 120mph in the rain...ran right over the damn thing. I used every single bolt and bolt hole it came with and even drilled some more evenly where I could put some plastic snap ins for extra hold. APR asked if I used the 2 adjustable bracket bolts (which I didn't) and said they wouldn't replace it if not used. Not that those two bolts would've done anything at that speed including a nice downpour to add more weight to the downforce even if you could find frame to bolt it into.
Old Feb 9, 2011 | 12:18 AM
F0RSAKEN's Avatar
So far so good, but mines only been on for ~1k miles.
Old Feb 9, 2011 | 04:54 AM
drift_Fan's Avatar
Ive had mine on since 2007 with no problems at all. still looks how it did when I bought it.
Old Feb 9, 2011 | 07:56 AM
PKEVO8's Avatar
nice I installed mine back in 2006. It was working great up until the hangers got effed up.
evo_xtatic, I remember seeing a couple of posts way back when of someone's who ripped off like that too. Do you think it was caused by the carbon fiber not holding up or the hangars failing?
Let's see some pics of your setups!
Old Feb 9, 2011 | 07:57 AM
justboosted02's Avatar
there's your problem
Old Feb 9, 2011 | 08:04 AM
L888Apex's Avatar
Are you talking about the two rods that go connected to the bumper near the intercooler? I will be putting my APR splitter on very soon and I have been worried about it staying on. Someone awhile back was talking about using larger washers than the ones that APR provides, so I might try that out and hopefully it stays on at the track at 150+ mph. Any other ideas?
Old Feb 9, 2011 | 08:12 AM
PKEVO8's Avatar
Yes that is excactly what i did. The washers that it came with seemed like they were almost cutting into the windsplitter, so i replaced them with some with a slightly larger diamter (increase surface area). It seemed to have helped, I'll snap some pics of mine on my way out
There was a ly evo here on the forums which I believe was a dedicated track car, and he drilled like 10 or 15 extra holes to mount the windsplitter, and I don't think he ran into any problems
Old Feb 9, 2011 | 08:20 AM
L888Apex's Avatar
Hmmm ok, I will look into it more once the time comes around for me to put it on. I would really hate to crash/cause an accident for someone else behind me at the track if the splitter came off I was thinking about mounting it to my OEM SE lip but some of the black tabs that hold it on are coming loose, so I might just buy a CF SE lip and use that instead.
Old Feb 9, 2011 | 09:58 AM
PKEVO8's Avatar
You can install it underneath the se lip but I think the hangars should be mounted on the actual bumper. I took some pics of my splitter but I can't upload them until I get home. You can definitely see stress cracks on the clearcoat where the hangars are bolted up, but everything else seems fine.
The splitter is definitely functional. I had some minor vibration in my steering wheel and after I installed the splitter it disappeared
Old Feb 9, 2011 | 05:18 PM
L888Apex's Avatar
Good to know and keep me updated please
Old Feb 9, 2011 | 05:27 PM
MitsuJDM's Avatar
Had one on my old Evo. It held up great to 160+ numerous times. I used bigger washers then what came with it.
Old Feb 10, 2011 | 04:02 PM
PKEVO8's Avatar
This is from a pm way back in the day, I haven't been able to find any pictures of vboy's setup though.
Originally Posted by vboy425
the front spliter does work if you reinforce it. if you just bolt it on from the factory screw, it doesn't do much. What i did with my is that i reinforce with 42 nuts and bolts total.
Old Feb 20, 2011 | 03:13 PM
evoiao's Avatar
i tried to install mine today but the holes didn't line up at all, one 1/2 did , but the other 1/2 was not even close. And even if the holes did line up it would have made the splitter look weird, one side was fitting flush with the wheels arch, but again the other side was sticking out about an inch to a half inch???? My under tray fit just fine, its the correct part for my yr, I have an 06 ix and the instruction stated this was for a 2006 to 2007 evo9? so why did this happen any ideas how to fix it???
Old Feb 20, 2011 | 05:03 PM
bbyevo8u's Avatar
that sux man did you go back and get it? i would fight for a new one if you can prove you bought it from somewhere!
m0nkie
Jun 1, 2017 03:49 PM
m0nkie
Jun 1, 2017 03:48 PM
03Roush2
Feb 6, 2016 10:31 AM
george3
Sep 14, 2014 10:17 AM
201Motorsports
Evo 'For Sale' Exterior Styling
19
Dec 14, 2009 09:17 PM
