Possible high idle??
Old Feb 23, 2011 | 02:42 PM
svt_lightning01's Avatar
So I recently got the car back on the road. It runs and droves perfect but it idles around 1000-1200 rpms it doesn't really fluctuate or act like it wants to stall. I will say it's tuned for about 23 psi and it's on wastegate pressure until Friday when o put the mbc back on. Also I am going to change the plugs also Friday because it has a very slight miss at idle. Would either the low boost or fouled plug cause the slight high idle?
Old Feb 23, 2011 | 07:13 PM
EvoDom's Avatar
Stock cams? Could be an idle sensor
Old Feb 23, 2011 | 07:18 PM
MRolla's Avatar
Could be you IAC vavle
Old Feb 23, 2011 | 07:19 PM
Hks 280 cams. No lope just a miss at idle with a slight high idle like I said. Hopefully new plugs cure the miss
Old Feb 23, 2011 | 07:33 PM
Would it be the iac? It's not choppy or anything it's smooth it's simply elevated from 800 ish which is the norm
Old Feb 23, 2011 | 07:38 PM
I guess the question I should ask is more like what should an evo8 with aftermarket cams idle at? Is it in the tune perhaps?
Old Feb 23, 2011 | 07:52 PM
polish_pounder's Avatar
I have the same problem my car has been idling 1000-1200 rpms and my cel keeps coming on for iac control idle to high. Is my iac possibly bad? N where can I get a new one
Old Feb 23, 2011 | 08:38 PM
prolly have to go through mitsu or get one offline. If you are getting that code i would check the iac valve for sure. Mine has no code just the idle.
Old Feb 23, 2011 | 09:47 PM
barneyb's Avatar
For cams, it sounds about right to me. I say the tuner set it to that idle.
I'd suggest you try turning the steering wheel stop to stop while not moving and then try the A/C. If the idle stays steady durning these tests you are good to go.
Old Feb 24, 2011 | 03:51 AM
The iac is the black piece on the lower end of the throttle body right? I just unplug it unscrew it n clean it?
Old Feb 24, 2011 | 05:41 AM
I read somewhere u can test the iac by un screwing it but leaving it plugged up and turn the key over. Don't start the engine. Just turn key to on position. Apparently the valve has a stick that will move up and down searching for idle position when it's unscrewed. Perhaps you can use this to see if it's bad if that's true.
Old Feb 24, 2011 | 06:23 AM
Thanks for the advice I had my throttle body off but was scared to take that out lol. Would it be safe to spray with trottle body cleaner? I herd that its possible for it to get dirty and it can clog or block the sensor if its dirty
Old Feb 24, 2011 | 06:35 AM
4RETECH's Avatar
Iac, dealers sell for $300. Amazon sells for $160. My chrysler dealer got me mine for something like $106 if I remember correct, but that was dealer wholesale price.
G serial number engine on the Sebring, uses the same iac
Old Feb 24, 2011 | 11:21 AM
i dont think mine is the iac it seems more like its tuned to the car because its smooth with no jumps or spikes reguardless. Hopefully the plugs cure the miss when i change them out tomorrow
dsmluck
Aug 23, 2023 12:33 PM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
mrfred
Feb 17, 2015 09:05 AM
karlr
Oct 15, 2008 08:43 PM
Boltz.
Jul 12, 2007 01:38 AM
