Stripped lug nut?
Old Mar 1, 2011 | 02:20 PM
mullski's Avatar
Stripped lug nut?
I think I stripped a lug nut and have no clue what to do. I don't even know how i did it but I went to take it off and it kept spinning and wouldn't come off. Does anyone have any experience or ideas on what to do. I don't need it off any time soon, but I am sure I will sometime.
Thanks
Old Mar 1, 2011 | 02:21 PM
dac001's Avatar
beat a socket on it. or impact Gun.
Old Mar 1, 2011 | 02:35 PM
cfdfireman1's Avatar
^fail^
If the lug nut is turning but just spinning on the stud you can remove the 4 good lugs and pull gently on the wheel to remove the bad lug. Then replace or most likely you'll need to replace the stud also.
Old Mar 1, 2011 | 06:53 PM
elementsk8erq's Avatar
^^^^ What he said
Old Mar 2, 2011 | 04:16 PM
mullski's Avatar
thanks I will give that a try
Old Mar 4, 2011 | 10:37 PM
An04EVO's Avatar
Any luck getting the lugnut off?
We had that happen on a Ralliart we had. Ended up drilling out the lug bolt. Being careful not to damage the rim. Needed to have a hardened drill bit and lots of patience.
Actually used a couple different size bits, started small in the center of the lug and went up to larger drill bits until we had a hole almost as big as the diameter of the lug, and then with a pry bar got the wheel to pop off, breaking the rest of the lug bolt off.
Then had to replace the lug. Used a lug nut, and a bunch of washers to pull the lug bolt through and get it seated all the way before putting the wheel back on.
Old Mar 5, 2011 | 04:20 PM
mullski's Avatar
I haven't tried yet I am in school and my spring break is next week so I will it a shot then. Thanks for the advice and I hope I don't have to drill.
Old Mar 5, 2011 | 04:50 PM
An04EVO's Avatar
Not so bad if you do, just takes a little bit of time.
Good Luck.
Old Mar 12, 2011 | 10:14 PM
well how'd that work? gently pull on the wheel to apply pressure to the lug-nut as you turn it.
Gtizks
11
Jan 5, 2017 08:11 PM
VishnuEvo8
Jul 25, 2015 12:55 PM
TxFAkuma
Apr 17, 2015 10:07 AM
bmxking45
Aug 18, 2012 08:29 PM
mitsuevodriver
May 9, 2010 07:21 AM
