a/c delete serp belt
Old Mar 30, 2011 | 01:51 PM
zevors's Avatar
does anyone know the belt length and/or a part number for a serpentine belt for an 05 evo with the a/c deleete??
Old Mar 30, 2011 | 01:52 PM
EvoDan2004's Avatar
same as the Evo RS. call mitsu and tell them you need a evo RS non a/c belt.
Old Mar 30, 2011 | 01:59 PM
zevors's Avatar
i have the rs but it has the ac unit in it..my compressor is shot and i'm trying to just bypass the pully for now until i can pull it out..if u know a number or a size that would be awesome
Old Mar 30, 2011 | 02:20 PM
tisthisevo's Avatar
belt
go to stm website they have the a/c delete belt on there
Old Mar 30, 2011 | 02:33 PM
EmeryatSTM's Avatar
Here is a link to it
http://www.streettunedmotorsports.co...moval_belt.htm
Thanks
-Em
Old Mar 30, 2011 | 05:31 PM
mxguy1286's Avatar
Or a belt from a bmw m3 2003 works
Old Mar 30, 2011 | 05:35 PM
milford's Avatar
or you can do what i did...go to napa and ask for a 57 inch 5 rib belt. costed me 13 dollars.
Old Mar 30, 2011 | 05:36 PM
milford's Avatar
actually i believe anything from 57-59 inches will work.
Old Mar 30, 2011 | 06:13 PM
TommiM's Avatar
I have read threads on here from guys who delete the a/c, swap in a a/c delete belt and having issues with the power steering pump pulley. Im not sure if its using the wrong size belt causing stress on the pulley bearing or what. I have seen at least 4 different part numbers being thrown around while searching for threads about a non a/c belt. Anyone have experience with the STM belt listed above? I am looking to delete my a/c as well.
Old Mar 30, 2011 | 06:19 PM
Force-Fed Performance's Avatar
part number is gates K060578 i believe.. part transfers over to a dayco belt you can pick up at any local auto parts store
Old Mar 30, 2011 | 06:24 PM
kanyonkid's Avatar
go to napa and get it its like under $20 bucks by gates too.. 57.5" 58" 58.5" is what you need. 57" is a lil to tight imo but it will still work.
Old Apr 4, 2011 | 04:06 PM
TommiM's Avatar
5 rib belt posted above is incorrect. I didnt look closely enough until I took the old belt out and noticed that it was a 6 rib belt. I hope the length was correct. I will go to napa and see what they got.
Old Apr 5, 2011 | 01:45 AM
omniprobe's Avatar
Do you remove the A/C pump or just bypass it?
Old Apr 5, 2011 | 04:33 AM
TommiM's Avatar
Im removing mine.
Old Apr 5, 2011 | 11:45 AM
5 ltr. beater's Avatar
any benefits to unhooking the a/c and deleting it besides saving weight?
