View Poll Results: Best bang for my buck to 600WHP build
Evo VIII Non ACD
27
43.55%
EVO VIII with ACD
9.68%
EVO IX 5 Speed
27
43.55%
EVO X
3.23%
Voters: 62. You may not vote on this poll
Best Evo to build???
Old Mar 31, 2011 | 01:04 PM
dambikeracer's Avatar
I had an IX for two years that I put 30k into and had to get rid of do to financial reasons. Now that things have settled down and I'm back on track, I want to see about getting another Evo. I'm looking to find one that someone has already put some money into and needs to get rid of, for whatever reason.
I do a lot of drag racing but the car will also be my DD (I think). Looking for a 600 WHP car with a 2.2L and since it might be hard to find exactly what I'm looking for, I want to find out what's the platform to start with is??? At this point, I'm thinking a 2004 RS because it is does not have ACD. Give me your thoughts and feed back.
Old Mar 31, 2011 | 01:12 PM
kwanza's Avatar
If you can find an VIII RS you will have a front LSD.
Old Mar 31, 2011 | 01:16 PM
Houstonsc300's Avatar
An VIII GSR doesn't have a front LSD? Why is that?
Old Mar 31, 2011 | 01:25 PM
llDemonll's Avatar
They just decided against it when building them
Old Apr 1, 2011 | 07:24 AM
acidtonic's Avatar
VIII RS 5speed has a titanium/aluminium alloy turbine wheel but it has a smaller 9.8t housing.
VIII MR RS 5speed has a titanium/aluminium alloy turbine wheel but it has a smaller 9.8t housing.
VIII MR RS 6speed has a titanium/aluminium alloy turbine wheel and has a bigger 10.5t housing.
(I don't think every country got the MR RS)
When pushing the stock turbo to the limits, aren't these titanium wheels less reliable than the standard non RS turbine wheel? So technically I would rather stick with MIVEC and the standard wheel with 10.5t. If you're swapping the turbo, who cares?
Old Apr 1, 2011 | 07:35 AM
4RETECH's Avatar
Most of the guys I know who track, road race build 8's and 9's. only one or two tens. Ten's seem to be heavy for the track.
Yes, a great car would be an RS if you can find one.
Good Luck
Old Apr 1, 2011 | 07:37 AM
wizzo 8's Avatar
Starting in maybe 04 but for sure 05 all evos have limited slip front diffs.
Old Apr 1, 2011 | 07:53 AM
SubieEvoGuy's Avatar
well if your going for 600whp and you drag once in a while. your going to want a built t-case... so just get front lsd when you build the t-case
Old Apr 1, 2011 | 08:44 AM
djikonatx's Avatar
sorry to step the OP's thread but
does anyone know how to tell if you have a t-case with a front lsd without opening it.?????? sorry i have an extra one laying around and i think it was from an 04. sorry for the noob question
Old Apr 1, 2011 | 08:46 AM
andrewzaragoza's Avatar
for drag get the cheapest since you will need to upgrade just about everything. you can add the lsd later when you build the tc.
Old Apr 1, 2011 | 09:24 AM
MonsterEvol23's Avatar
The easiest way to tell if the t-case is an lsd one or not is by looking into where the axles go. There's a bar that runs through the non lsd ones.
Old Apr 1, 2011 | 09:39 AM
acidtonic's Avatar
I'm not sure if it would work but you might be able to jack the front up and slightly rotate the wheel to see which behavior you get from the other side. After spinning one wheel clockwise, the other wheel should rotate counterclockwise if both are off the ground. My only concern is the front LSD is not a clutch-type, and I don't know if that test works on non clutch-type LSDs.
Upon putting bricks under the other front tire to provide resistance, you should be able to spin the other side and get the wheel to knockover/slide the bricks. An open diff would never do that and with one in the air, one on the ground, the air side would spin freely before ever applying much force to the bricked tire. Normally you need some kind of resistance to get the LSD to do it's magic.
We did similar things to Mustangs with various rear diffs but I'm not 100% sure that works with AWD. I assume keeping the rear on the ground forces the front to apply the remaining power to the only other wheel that has less resistance than the rear. For some reason I keep feeling this is not accurate but I'm making an attempt. Perhaps someone with more Evo specific knowledge can chime in since I'm curious.
Old Apr 1, 2011 | 11:38 AM
BlackEvo_5's Avatar
Yup the test should work.
Old Apr 1, 2011 | 11:51 AM
atxMR's Avatar
You should buy an VIII or IX that gives you the most bang for your buck in achieving your final goal. At 600AWHP you're looking at built motor, tranny, transfer case, and rear end. The ideal purchase for those goals IMO would be to buy a shop/ race car that's been built to the extreme you're looking at and then find an interior for it.
Old Apr 1, 2011 | 12:55 PM
I guess that I should rephrase the question I had, I had a IX and was told for drag racing it is best to delete the ACD or getting a car without the ACD. I know what it's going to take to build a 600WHP car, that's not the issue. I've been looking for a 2004 RS and want to find out if there's going to be a better platform to start with?
In my IX MR I had to put a 5 speed tranny in because the 6 is a piece of **** and I blew it up.
