Idle Problem
Old Mar 31, 2011 | 09:37 PM
Sacevo9mr's Avatar
Idle Problem
To start off my check engine light came on for front 02 sensor, car didn't like to idle, would sit around 800 then randomly drop to 300 for a second and come back up to 800, drops down about every 10sec or so.
So i changed 02 sensor with new factory 02 sensor and cleared the light, went out for a test drive and now the idle is still doing the same thing.
Everyone so far has lead me to believe its a vacuum or boost problem but can't seem to find the problem anywhere..
Car drives perfect, its only at idle
all suggestions would be greatly appreciated
Old Mar 31, 2011 | 09:46 PM
BLK_EvIL's Avatar
Id check all vacuum line, egr lines like to come off. Disconect the battery for 15min and start up and let idle for 10min and dont touch the gas. Also maby check the IAC out see if its clogged up or not working.
Old Mar 31, 2011 | 10:28 PM
Brsox10288's Avatar
What are your mods?
Old Mar 31, 2011 | 10:47 PM
Sacevo9mr's Avatar
All bolt ons, but I doubt its anything performance wise. It just started happening once sensor went out
Old Apr 1, 2011 | 11:43 AM
Vehicle336's Avatar
Check your Idle air control valve. It's in your throttlebody and it's 400 bucks to replace.
Old Apr 1, 2011 | 11:56 AM
4RETECH's Avatar
Check the IAC/ISC, also get it from either Amazon or Chrysler for cheaper.
Old Apr 1, 2011 | 12:22 PM
Sacevo9mr's Avatar
What am i looking for? How can i tell if its bad, also what would cause it to go bad?
Old Apr 1, 2011 | 03:59 PM
warstang27's Avatar
its a little roundish black piece on the throttle body held on by three screws in a triangle form. they go bad because theyre plastic internals and strip out i believe. mine went bad too and had to replace it. thankfully i had a spare on my old throttle body. you might wanna check the f/s section for a low mileage used one
Old Apr 1, 2011 | 06:00 PM
CJ2X's Avatar
I have the same exact problem.. I've been trying to figure out what it is..
Here's a short vid..
It happens in the first few seconds..
Old Apr 1, 2011 | 06:10 PM
4RETECH's Avatar
http://www.amazon.com/gp/aw/d/B003QW...1706521&sr=8-1
Old Apr 1, 2011 | 06:20 PM
CJ2X's Avatar
Is that just a straight swap or is that something that me and the OP would have to take to a shop?
Old Apr 1, 2011 | 06:44 PM
Sacevo9mr's Avatar
identical to my problem just drops a little lower.
Old Apr 1, 2011 | 07:18 PM
CJ2X's Avatar
Mine varies.. Have you noticed that it does it after you've been driving for a little and then come to a stop..?
Old Apr 1, 2011 | 07:23 PM
Raistlin's Avatar
Mine does this a bit more so when it is colder.
I figured it was due to still being in the "build" period with no tune as of yet.
Sacevo9mr's Avatar
Yes sir, its not bad when first start it but from light to light, its bad
