A quick question...
Old Apr 2, 2011 | 04:04 PM
effmylife's Avatar
A quick question...
Recently, ive been experiencing some break issues. Not so much a problem really, but an annoyance. The right break has started not to squeak, which i realize is common, but make more of a crunch noise. I'm not too sure how to explain it, but, at a stand still, if i press the breaks a bit hard, it makes a crunch noise, like metal on metal. I checked the break pads out, and they're not worn out or anything. I've tried hosing the mother lover down to get rid of break dust, but, no cigar.
What else could it be?
Old Apr 2, 2011 | 05:01 PM
ReaperX's Avatar
What kind of pads are they?
Old Apr 2, 2011 | 05:04 PM
Rich_1's Avatar
Did you recently replace the pads?
If so - did you resurface the rotors or replace the rotors?
If not - how many miles (rough) are on the pads?
buchnerj's Avatar
Do you have shims on there? Were they properly greased upon install? How long have you had those brakes on there, are they a recent install or have they been on there for a while?
Old Apr 2, 2011 | 05:25 PM
effmylife's Avatar
they're the stock pads. cant say for sure how many miles were put on em', i bought the car used, but, its not so much a squeal as it is a crunch.
i haven't done anything to the breaks upon buying them either
also, i was told the breaks were relatively decent, and, are in working order. not all the breaks are making this noise, just one.
Old Apr 2, 2011 | 07:42 PM
tweakers-r-us's Avatar
i would say take it to a shop to check it out. ur calipers might need some greasing or something...
Old Apr 3, 2011 | 12:19 AM
elementsk8erq's Avatar
I would check the pads again if I were you. The stock brembo brake pads wear out quick!
Old Apr 3, 2011 | 12:17 PM
effmylife's Avatar
while that may be the case, there are 3 other pads that should have been semi worn out, but, they're fine as well. I've checked out the pads. They're fine...not too worn out.
