evo help
Old Apr 12, 2011 | 08:25 AM
born2die88's Avatar
evo help
so my car cranks but dont start
i got sprk going to the ignition coils but dunno if the coils are good or not u guys think that could be the prblem
Old Apr 12, 2011 | 08:37 AM
dastallion951's Avatar
any check engine light codes??? what you could try to do is remove uicp to throttle body spray a little bit of engine start spray, into it put uicp back on, try startin it, if it cranks over starts then dies, you know its a fuel issue...
Old Apr 12, 2011 | 08:47 AM
Sacevo9mr's Avatar
^^ That, but keep your clamps loose, give it multiple tries to make sure.
Old Apr 13, 2011 | 05:38 AM
born2die88's Avatar
yeah i didi do that it felt like it was about to start but died.
i got someone to get the fuel pump working and it comin all the way thru
but still dont start
and i got no check engine lights
Old Apr 13, 2011 | 10:09 AM
what you can do to rule out the fuel pump, im assuming you have a walbro pump in tank, since its not starting, swap in the stock fuel pump to check to see if its working....or you can pull out the pump assy, make sure the connector is plugged in properly, and all the fuel lines are securely attached, theres not much else that can cause a crank but no start, any leaks in the fuel lines, injectors etc?? or what you can try is jump starting your vehicle a bad battery, jump start it should provide enough juice for it to crank over...check with a voltmeter on both terminals to see what the volts is currently on it
Old Apr 13, 2011 | 10:12 AM
sharkm87's Avatar
first off, did you do anything before this happened..tried to flash a rom?...install injectors..reset ecu??
if one day you just went out and it wont start than to check fuel you can just pull the fuel line crank for sec to see if fuel is coming out..
also could be a bad crank sensor
Old Apr 13, 2011 | 10:17 AM
05blue8's Avatar
Check fuse 1 under the driver's side dash
