evo 9 turbo install kit (sorry)
Old Apr 18, 2011 | 10:22 PM
EvOstyleZ's Avatar
I know this question has probably been asked a million times, but I did some searching and got 3 different answers.
Which evo 9 turbo install kit is the most accurate complete kit?
Which one has the best deal..
thanks!!
Old Apr 18, 2011 | 10:29 PM
chaotichoax's Avatar
go to forced performance's website
they have pictures that show what you are getting
Old Apr 18, 2011 | 11:12 PM
Evoluvin's Avatar
I am also wondering this. I understand FP has one. But it is a little pricey for what you get.
Old Apr 18, 2011 | 11:25 PM
SOEuro's Avatar
I just bent my stock lines when I installed the ix turbo. Works fine
Old Apr 19, 2011 | 03:40 AM
bigben's Avatar
http://www.mitsubishiparts.net/catalog/?section=652
the 5th thing from the bottom, is this what you are looking for?
Old Apr 19, 2011 | 04:40 AM
sphinxof2006's Avatar
thanks!!
FP kit is LEGIT! i run the FP gaskets
http://store.forcedperformance.net/m...Lancer-TurboHW
Old Apr 19, 2011 | 05:07 AM
Mellon Racing's Avatar
Gen1 kit http://www.mellontuning.com/index.ph...roducts_id=460
Gen2 kit (includes oil line to get pressure from the filter housing instead of head) http://www.mellontuning.com/index.ph...roducts_id=459
Old Apr 19, 2011 | 05:42 AM
gsrboi80's Avatar
Honestly unless you are needing the FP specific oil line from the filter housing then all you really need for 0 fab is a IX J Pipe.
Hell you really dont even need that in a pinch. Heat the VIII J-Pipe and bend it away from starter
DONE
Old Apr 19, 2011 | 06:28 AM
blknblubkrdude's Avatar
^ That is the most complete kit out there. It is a good deal and genuine Mitsu parts.
I bought my full hardware set for my turbo/manifold/O2 from them also.
Old Apr 19, 2011 | 06:38 AM
MaLo EvoVIII's Avatar
Make sure not to buy an ebay install kit. I made that mistake and I learned the hard way. The gaskets that come in those kits are garbage and so are the banjo bolts.
Old Apr 19, 2011 | 07:28 AM
Blue95GST's Avatar
The only 2 things you really NEED are the oil return line and j-pipe, oil feed and coolant lines have plenty of wiggle room to work fine
Old Apr 19, 2011 | 07:40 AM
EvOstyleZ's Avatar
So it seems this is the most complete kit at the best price from what im hearing, anyone say otherwise, is there anything else ill be missing? Im trying to avoid downtime when it comes to the install
I wont be buying the ebay kit, im afraid the parts will be cheap and affect me in the long run.
Old Apr 19, 2011 | 05:52 PM
EvOstyleZ's Avatar
One more question..
What about the oil return lines? there not in the fp performance install kit.
Ive seen a picture where the evo 9 oil return line is a bit longer that the evo 8 return line.
Old Apr 19, 2011 | 06:02 PM
One more question..
If you need the oil feed line (the one that goes from the turbo to cylinder head) you can get it from MitsubishiParts.net for cheap.
http://www.mitsubishiparts.net/catal...ction=693#1810
Old Apr 19, 2011 | 06:21 PM
EvOstyleZ's Avatar
Thanks!
Is it needed though? I find it kind of strange that the oil return line isnt in the FP kit
