Suspension is stuck
Old Apr 28, 2011 | 08:06 AM
Racco's Avatar
Suspension is stuck
I was driving and hit a pothole pretty hard but didn't think anything of it until I felt my car pulling to the left. I got out the car and noticed that my front suspension was lifted, mind you, I have lowering springs.
Could it be that the strut(s) are shot, causing one or both to lift? Has anyone had this issue before?
I replace the front struts about a year ago...
Thanks
Old Apr 28, 2011 | 08:12 AM
Bobster22388's Avatar
A blown strut would not cause your car to lift. I think you have some more serious problem. Kinda hard to diagnose over the internet though, especially with no pics.
Old Apr 28, 2011 | 02:35 PM
spdngdragon's Avatar
If you bend the strut then the suspension will be stuck in the position that it is in when it got bent... good luck
Old Apr 28, 2011 | 02:38 PM
FYI a bent strut (think piston rod here) and a blown strut (think valves and seals) are two different things
Old Apr 28, 2011 | 02:51 PM
sr20det91's Avatar
Its on of two things: a bent strut rod, as stated above or a bent control arm the has everything wedged up. I can't see anything sway bar related that would really cause binding like that.
Old Apr 28, 2011 | 03:06 PM
EVO8STI's Avatar
i say bent or the spring is on the lip of the strut
Old Apr 28, 2011 | 03:26 PM
Pitside's Avatar
Guys struts do not hold the weight of the car. Springs do, even if one is bent it will crack the housing and not hold the car up. All a strut does is dampen spring Jounce and Rebound forces.
I will agree with the few that mentioned bent control arm, this will change ride height. It should be obvious to the tech that looks at it if you take it in.
Old Apr 28, 2011 | 04:07 PM
elementsk8erq's Avatar
Did the spring pop out of the perch?
Old Apr 29, 2011 | 08:07 AM
Racco's Avatar
I took the wheel off and everything looks normal, nothing is bent, spring looks good & in place.
Still puzzled.. I'm going to take it in this weekend.
Thanks for the pointers!
