Popped an intercooler hose off today at 80mph
Old May 1, 2011 | 07:57 PM
thegoodservant's Avatar
I haven't changed anything at all recently. 1st hot day of the year wonder if that had anything to do with it? Sucked, I was way out a country road with no tools.
Old May 1, 2011 | 08:13 PM
ReaperX's Avatar
Clamp was probably loose already. Get some t-bolt clamps if you don't have them already.
Old May 1, 2011 | 08:52 PM
awdordie's Avatar
may have just finally worked its way loose. i usually try to do a boost leak test every other oil change or so just to eliminate the possibility
Old May 1, 2011 | 08:59 PM
nonschlont's Avatar
t-bolt clamps and/or hairspray... Yes, I said hairspray... spray the piping that the coupler goes on, just before placing the coupler on. I would advise upgrading clamps tho... I went thru a couple, before I realised I was overtightening them/fkn them up...
Old May 2, 2011 | 04:12 AM
sleeper04's Avatar
+1 on the hairspray worked great for me !
Old May 2, 2011 | 05:02 AM
bonsuz01's Avatar
Hairspray... Cool. I carry screwdriver. just in case..
Old May 2, 2011 | 05:34 AM
TTKID's Avatar
Always keep a small tool case in my car just in case. Rather be safe than sorry.
Old May 2, 2011 | 05:41 AM
Chemwarrior's Avatar
I always carry a multitool in my car just in case.
Old May 2, 2011 | 06:03 AM
__pg's Avatar
Same thing happens to me ALL the time and it SUCKS. I actually lost 2 t-bolt clamps this weekend at 129. I have lost many and CANNOT figure it out. I have cleaned with alcohol and used hairspray as well as tired both 3" and 2.75" clamps. I am using the stock upper piping and hoping the mini battery with aftermarket piping will remedy this.
I always carry extra clamps and tools. Not saying it will happen to you like this just saying it does happen.
Old May 2, 2011 | 07:41 AM
stevenkha's Avatar
A small tool case is definitely a good idea to have in your car!
Old May 2, 2011 | 09:13 AM
I have the stock IC and Injen piping it's hard to get them to line up properly "angled hose" I wonder it it would be harder to blow off one on one of the larger IC's where you'd use a straight hose. I have plans for an ETS intercooler next month.
Old May 2, 2011 | 09:23 AM
acidtonic's Avatar
Both times I lost the main throttlebody clamp... I got lucky that it stayed stuck under the car and not back on the road or I'd have been walking to find it.
Now I keep an extra T-Bolt clamp and a leatherman in the car.
Old May 2, 2011 | 01:08 PM
Jschlo4's Avatar
Same thing happened to me on I 95 a couple weeks ago. Of course I had taken my tool kit out for some stupid reason. Luckily I realized the spare tire kit had a "flat headish" tool in it. Needless to say it was the scariest moment in my life.
Old May 2, 2011 | 02:14 PM
EVOgirlie8's Avatar
I second ReaperX. This happened to me at one point - i got t-bolt clamps- havent had an issue since.
Old May 2, 2011 | 02:26 PM
warstang27's Avatar
i put a small layer of rtv on all my couplers and t clamped them all, holds 27lbs no problem
