idle From Hell
Old May 4, 2011 | 02:46 PM
dac001's Avatar
Angry idle From Hell
update ::: thsx C130flyer your looping the vaclines WORKED for me...... {thum bup}
Quote:
Originally Posted by C130flyer View Post
Well I am very pleased to tell everyone on this thread that after forever I finally fixed it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
I deleted the EGR vacuum lines by looping the 2 vac lines on the top of the throttle body back into each other and presto fixed yeah!
Must have been the egr solenoid or associated vac lines leaking lol.
__________________
http://www.youtube.com/watch?v=Wb475oWhdoY
Hello need some help or tip's on what this mite be. cold start car idle's find when it get's up to running temp's the idle go's to S^*T. the car is not throwing any codes. a buddy of mine says its the intake manifold gasket have replaced it and done the following with no success..
replaced plugs
checked for vacuum leaks
replaced isc/iac
cleaned EGR valve
replaced intake manifold gasket
boost leak test
Old May 4, 2011 | 03:08 PM
20austin08's Avatar
did you try activating the SAS mode in ECUflash and then adjusting your biss screw to get your idle to where you want it? Is that all of your mods in your sig?
Old May 4, 2011 | 03:16 PM
dac001's Avatar
have not tried SAS mode yet. yes that is all the mod i have.
Old May 4, 2011 | 04:32 PM
dac001's Avatar
bump...help
Old May 4, 2011 | 04:53 PM
wizechef's Avatar
I had that prob for a while! Did boost leak tests, all sorts of cleaning, even got some dyno tuning done. Couldn't figure it out. Finally I gave up, got all new piping and went to speed density! Never looked back. And I got a little more power out of it too...
A lot of owners on here seem to have this issue... If you can't figure it out I suggest you look into SD
Someone told me to try to go back to the old rubber intake boot. Maybe give that a try, and see if the idle issue is still there...
Old May 4, 2011 | 04:58 PM
EvoVIII03's Avatar
Make sure the screw did not pop out of your throttle body. I don't know if it's an issue on evos but my brother has a 3000gt vr4 and the screw is actually plastic and it popped out causing a bad idle.
Old May 4, 2011 | 05:06 PM
evo milk's Avatar
Maybe it's because you have chickens for vacuums leaks...sorry I have nothing to contribute.
Old May 4, 2011 | 05:09 PM
victorr's Avatar
I'm going through something similar but it would happen intermittently, but mostly during clutching in from 1st to Neutral at a Stop. Idle would dip below 500 then back up. Operating the AC would make my idle drop worse--and really stall the car at a stop. I've done everything you've done with the addition of cleaning my PCV valve and making sure it is operational (shaking it and hearing the vlave go up and down). Have you cleaned your PCV valve yet? Also, check that the lines to the EGR are all connected.
I ended up cleaning my IAC and reinstalling it and everything went fine for a day until the IAC crapped out again..not sure why. I have another IAC I need to reinstall and hopefully my problems go away. And YES, actuate SAS (turn it off) before messing with the BISS. Get the idle right, then actuate it back on.
Old May 4, 2011 | 05:40 PM
nytalonTSi's Avatar
Originally Posted by 20austin08
did you try activating the SAS mode in evoscan and then adjusting your biss screw to get your idle to where you want it? Is that all of your mods in your sig?
This will most likely help your issue and you need to do since you replaced the iac. Do you have a tactrix cable and evoscan?
Once you activate the actuator your idle will most likely be low you want to set it to 850rpm. Then will have to reset the battery.
Old May 4, 2011 | 06:16 PM
dac001's Avatar
thxs for the info will try all the above - the chickens
Old May 4, 2011 | 06:34 PM
dac001's Avatar
log
here's a log of it idling...
Old May 5, 2011 | 02:06 PM
dac001's Avatar
can someone take a look at the Log ?
Old May 6, 2011 | 02:37 PM
dac001's Avatar
anyone out there?
Old May 9, 2011 | 02:03 PM
turboback1243's Avatar
have you taken your battery out of the car recently?
Old May 9, 2011 | 02:09 PM
dac001's Avatar
no y? i got a new one maybe six mounts ago car was running fine...
