Mivec problem
Old May 4, 2011 | 06:27 PM
evolvd276's Avatar
Mivec problem
What would happen if the mivec goes bad I recent did a build and drove it 300 miles and started getting a ticking noise replaced the litters and the car has good compression and starts fine
So the mivec is locked up and is making a bad noise. Help please
Old May 5, 2011 | 11:09 AM
acidtonic's Avatar
Slow down... tell us more. What did you build, why do you think it's MIVEC?
Did you just install cams without bleeding the lifters? They HAVE to be bled or it will tick and possibly cause damage.
We need more info to go on here....
Old May 5, 2011 | 11:55 AM
BLKCarbonEVO's Avatar
Agreed, need more info!
Mikey
Old May 6, 2011 | 02:05 PM
evolvd276's Avatar
ok i just finished my 2.4 mivec build and i primed the cam gear , and oil pump it should have primed the lifters there was oil coming up from them .
any ways i gotr the start up tuned alright and started have what seemd to be a lifter ticking so my guy was like no big deal .
we drove the car 330 miles checking over everything visable like every 50 miles so i am going up a incline on my way home and i get a miss . then thats when th noise started getting louder it sounded some what the same but louder and constant but accels as the car revs come up
we changed the lifter and notice the cam gear was locked , so my guy took the gear apart cleaned it and the noise is quieter and changed pitch it sounds exACTLY
like a few on here that have posted viedeos on thinking lifters are bad and some changed the cam gear.
the only think we didnt put back in was the mivec filter . any idea what coulda happend
Old May 8, 2011 | 11:43 AM
evolvd276's Avatar
Bump trying to figure out if it's the mivec
Old May 8, 2011 | 02:05 PM
autotechnica's Avatar
Lack of filter allowing particulate to block oil passage holes and or solenoid valve assy.
MRadjahoe
Nov 1, 2016 11:33 AM
whatever210
Oct 19, 2015 07:18 PM
fireroasted
Oct 6, 2015 04:41 PM
fireroasted
22
Dec 21, 2013 12:26 PM
meld
Jan 24, 2011 07:46 PM
