car wont start
Old May 7, 2011 | 10:01 AM
IllusionAstarz's Avatar
car wont start
need help guys.i recently had a blownheadgasket.i parked the car for about 3 weeks and now i try to start it and it doesnt start.the battery voltage is full and it cranks when i try to start it but it wont start.what do you guys think it could be?
Old May 7, 2011 | 10:04 AM
awdordie's Avatar
Obviously u pulled the head to change the head gasket so have u checked the obvious things like timing, fuel, spark?
Old May 7, 2011 | 10:10 AM
i was going to drive it right down the street to the shop so i could drop offf the car..
Old May 7, 2011 | 10:11 AM
quick silver 8's Avatar
wait, did you fix the head gasket?
Old May 7, 2011 | 10:14 AM
no i was going to drop off the car today to get it fixed until it didnt start.
Old May 7, 2011 | 10:29 AM
Bobster22388's Avatar
Just because the battery voltage is good doesn't mean the battery is. You have to load test a battery and find out what Cold Cranking or Cranking Amps it has left.
Did you unplug any sensors? Any CEL's?
Old May 8, 2011 | 08:31 AM
i didnt unplug anything and no cel.i noticed the blown headgasket when i found oil in the coolant.so i stopped driving it.
Old May 8, 2011 | 08:49 AM
Most Hated's Avatar
whats it doing. do you hear the starter? is it not turn overing? do you hear any relays?
Old May 8, 2011 | 08:54 AM
SpoolinUp's Avatar
Silver Sponsor
Check the 10a interior ignition fuse behind the change holder compartment near your left knee.
Also check cam sensor (broken wires), broken cam sensor, crank sensor plug (top left of valve cover), and ignition connectors (broken wires).
Do you hear the fuel pump??
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old May 8, 2011 | 02:45 PM
i will check all of that later today and see what it could be.
