Oil leak cant find it!!
Old May 12, 2011 | 11:29 PM
CraZyx978's Avatar
where is the crush nut? becuase mines leaking too.. it gets on my downpipe..
Old May 13, 2011 | 11:43 AM
Dan0805's Avatar
Take off your drain plug, it looks like a washer that sits at the base of the threading.
Old Jun 20, 2011 | 09:14 AM
lazyrichi3's Avatar
I have a leak as well, I think it might be coming from the oil pan and the oil return line... I called dealer and they wanted $26 per washer and each line uses 2 washers on each end... and $26 is MY cost as a bodyshop... Sorry to bring this thread back up but has anyone had this issue before of if they found the same washer for cheaper? =]
Old Jun 20, 2011 | 09:45 AM
GrnEVO's Avatar
search the part number threads on here. go to google with the part number for the crush washer. (same number for transmission washer too) you can find them for between $1 - $5
Old Jun 20, 2011 | 09:52 AM
afgtrackstar's Avatar
good job!
Old Jun 20, 2011 | 05:05 PM
awdordie's Avatar
You can also use help brand brake hose crush washers found at any local parts store. That's what I used when the dealer wanted 4 bucks a washer. I think I paid like 5 bucks and some change and the pack has like 12 in there.
Old Jun 20, 2011 | 05:41 PM
hatakashi's Avatar
It could simply be the oil filter isn't tightened properly
Old Jun 20, 2011 | 07:07 PM
lazyrichi3's Avatar
i was just readin the sticky thread and couldn't find the part number... would you mind giving me it? =]
Old Jun 21, 2011 | 01:05 PM
lazyrichi3's Avatar
I found it, MR464563. Just if anyone in the future needed the part number.
And I made a mistake at the above post, dealer wanted $2.60 not $26, i heard wrong =X
