floor mounted harness
Old May 12, 2011 | 07:43 PM
evoforstevo's Avatar
hey guys done some research but turned up empty. does anybody know of a floor mounted 3 or 4 point harness for the evo 8? i don't want a harness bar or the rear seat mounted as this is a very dd. thanks for all your help evom!!
Old May 12, 2011 | 07:54 PM
awdordie's Avatar
What's wrong with mounting em under the rear seat? That's where I have mine mounted and the seat still fits over the top of them and retains the rear seatbelts for passengers.
Old May 12, 2011 | 07:56 PM
oh i guess i've only seen by the head of the rear seat. i guess you know otherwise? is it still comfortable for back seat riders?
Old May 12, 2011 | 08:02 PM
awdordie's Avatar
Ya what ur reffering to is a harness bar. Im running sparco 4 point and in the instructions it says the rear buckles are safe to use as a mounting point under the rear seat. This provides about a 30 degree angle which is the most u would want. If your in a serious wreck with them mounted to the floor it can compress your spine becuz when it stops you going forward its also pulling down. What I did was remove the rear seats unbolt the 4 buckles and mount the new harnesses along with the buckles in that location. Lengthened the harness and threw the rear seat back in.
Old May 12, 2011 | 08:04 PM
sweet man!! i'm lookin at a sparco 3 pt. it comes back to a single point, does this pull to one side noticeably?
Old May 12, 2011 | 08:14 PM
awdordie's Avatar
Im not for sure as mine are 4 point. And as for if its comfortable for back seat riders I've had no complaints about it either they straddle them both or have one leg inbetween the two and the other outside of the harness. And I also kept my stock seatbelts upfront so most of the time if someone rides back there I simply pull the shoulder harnesses back through the seat and just have em in the rear floorboard so they don't have to straddle them
Old May 12, 2011 | 08:15 PM
thank you so much for your speedy help!! gotta love evom
119Evo
May 2, 2016 06:28 AM
David Buschur
Dec 31, 2014 09:23 AM
Uscbryan
Jan 7, 2014 06:27 PM
tmaddox
Aug 10, 2011 08:03 AM
kingkyle
Jan 10, 2005 01:56 AM
