gauge cluster lights
Old May 24, 2011 | 11:52 PM
forc3 f3d's Avatar
drove my car tonight and realized somethings up with the gauge cluster. turn the car on with the lights OFF and the gauge cluster is lit up along with HVAC etc... turn the corner lights on and the cluster turns off, HVAC still lit... turn the headlights on and the cluster is still off, as well as the HVAC.
dont know where to start really? could it be a grounding issue?? worked perfectly fine prior to tonight.
Old May 25, 2011 | 12:06 AM
fast3voviii's Avatar
well the stuff should dim with your lights. possibly your dimmer is all the way off...
Old May 25, 2011 | 12:40 AM
walker992's Avatar
best thing is to go through step by step and make sure all your wiring is corect i did the same thing on my second gen eclipse i ended up having wires switched my mistake. but it might be something simple as a ground also
